Exhaust stud removal
As I don't have any welding equipment, and since there is enough meat left, I'm thinking I can use JB Weld with the nut.
If no go on the above, any suggestions?
Last resort is to pull the head and go to a shop and get it pulled.
2. Soak it with PB Blaster for a couple of days, put some heat from a heat gun on it, then apply PB Blaster.
3. Tap the end with a hammer to free up the threads, tap not pound.
4. After a couple of days of putting on the PB Blaster with heat and tapping, try a pair of vice grips on what is left of the treads and see if you can work it loose.
5. If not best to take the head off and have a machine shop remove it and put new studs in so the head is not damaged.
NOTE:
The above information, while credible, is worth what you paid for it and should not be considered gospel.
Do due diligence, research and have a H-D Field Service Manual before working on your bike.
You will probably have many opinions and suggestions presented; make sure you research the person providing the helpful information as there are some who provide good information that is useful and some who speak out of other orifices with gibberish. You will figure out this quickly.
For a DIYer I have seen a jig that fits over the good stud and lines up to drill out the old and a tap to clean out what's left of the stud.
As that possibly requires the head to come off I guess a good machine shop might just as well take care of it for you.
1. JB Weld is not going to do it.
NOTE:
The only thing I would add is (thinking out loud) and considering what I would do in this situation:
Take your time. Rushing usually leads to shooting self in the foot.
Lots (many) of the heat and penetrating oil cycles with the mild tapping as mentioned in previous post by Coolbreeze.
Also consider threading a nut or two on the broken stud (or a longer coupler nut). It will kind of protect the remainder of that stud threads while you do the hammer tapping sessions. With the nut(s) in place do the shock/taps routine as mentioned by CoolBreeze. Just don't bottom the nut against the head when tapping. Leave a slight gap between nut and head so you know your sending your tapping energy down the stud and not against the head.
Any access to air tools (air chisel with a blunt end to use for careful vibrating of the broken stud)?
Do you know anyone with a 110 volt mig?
When frustrated, apply penetrating oil and walk away. Plan to fight another day.
of course that’s 30 bucks towards the machine shop,,,
The hole is deeper than the stud so you can drill a hole right through the middle & fill it up with penetrating oil & let it soak.
All depends on what your options are where you live.
I would soak the the stud in ATF.
Then heat stud with a torch. Trying to break bond.
Let it cool and repeat ATF a few times.
Then ATF overnight.
There appears to be enough bolt for a possible double nut. Might have to grind down nut to half thickness.
Heat the head area near stud so the threaded part might perhaps expand.
Then use a small wrench to wiggle bolt back and forth.
If it wiggles then keep spraying..because it should start to thread out.
It does not look to be the worst at this time.
If your are impatient then just take bike to a mechanic as it does not look bad at this time.
