Headlight ground location 85flht
Old Apr 18, 2024 | 10:13 AM
jimkav's Avatar
jimkav
Default Headlight ground location 85flht
Burnt out new H4 lamp.
Probably Loose/poor headlight bucket ground
anyone know the ground location?
couldn’t find in manual
thanks
Old Apr 18, 2024 | 06:24 PM
t150vej's Avatar
t150vej
There should be a bulb wire connector with white, yellow and brown- may be black. That's the ground wire.
Take the dash off. Remove cable from the speedometer. Using a #0 phillips with at least 1.75 long shank, remove the odometer reset ****. Remove 2, 1/4-20 screws from the rear edge. Lift up at the rear, should slide back, up and off. Disconnect terminal block.
Look on the left fork at the air tubing assembly and you'll see an aluminum block. It'll have a terminal strip with male spade connectors. One wire is the anti-dive valve ground and the others are the grounds going to everything up front. They come from under the seat, left side frame just below and behind the master cylinder reservoir screws. I'd wager one of those spots will be the problem.
Old Apr 18, 2024 | 09:39 PM
jimkav's Avatar
jimkav
Step by step instructions.
Very kind of you!
Hanx!
har1690
2014-2024 Touring Models
Mar 17, 2024 10:48 AM
benson1603
Electrical/Lighting/Alarm
Jun 2, 2023 08:29 AM
SDrake65
Apr 23, 2013 06:23 AM
Skydive D-4107
Jan 24, 2012 12:58 PM
pococj
Aug 1, 2005 12:07 AM
