Downshifting issues
Bike level on bike stand,
Primary gets filled to her,
And if an evo, do not use fluid thicker than conventional 10-40 motor oil.
Thicker fluid, or fluid level too high, will cause stiction problems with the clutch plates nor releasing cleanly from each other, no maker how much you have the clutch lever pulled all the way in, or adjusted correctly.
I looked in my Harley service manual and it called for 26oz in the primary of my 1998 heritage but if it was a 1997 Heritage it called for 32oz. After putting in the 26oz it didn't look like enough so I ended up with 32oz in it. Also I did have the outer primary cover off to change the gasket so more oil came out than a normal drain and fill. Im not sure why the different amounts for a 1997 and 1998 evo ?
This is my first Harley, so please forgive me if this is an obvious fix!
I took my Softail out for it's first test run last night & noticed that I have to tap the shifter twice to downshift. I've removed the heel shifter & had to adjust the toe shifter downward, due to an ankle injury (I can't flex my foot upwards) Could this be a lever angle issue maybe?
Yes, no, maybe, since its mostly a problem with either trans lever loose to spine shaft, eccentric adjuster not set to have pawl teeth adjusted centered to shift drum rods with trans in 3'rd, or worn out pawl claws/pawn claws spring broken isntead. The first two are 5 mins fixes, while the later means trans is coming apart to fix shifter pawl isntead.
Seven Gables
16
Apr 10, 2022 09:41 AM
