Crankcase filter confusion
(which can be seen to the left side of the aftermarket air filter). But, I'm a bit confused as to the purpose of that filter and where it's connected. I traced the connecting hose to a round, black container in the back. It's in the video.
https://www.youtube.com/watch?v=BJFspMHl4ok
Do you know what that container is and what purpose this crankcase filter serves in this particular case? Thank you in advance
Still trying to figure out what the can.device below the arrow is doing?
Best guess, since it pumped to evap can, and port into it (what the port the arrow is pointing to), should be the tube off the carb float bowel port to that can.
Hence charcoal emission port out of carb, should be tubed to port that arrow above is pointing at on the left hand can.
Thank you very much for the detailed explanation. So, I guess everything is hooked up correctly? Just want to double check. From what I understand, the evap can be discarded if I choose so, but what are the advantages of discarding the evap caninster?
yer gonna have Problems..
stick with the OE in tank strainer
This is what I installed:
https://www.lowbrowcustoms.com/produ...31149413400623
Thank you
Thank you
I will Never
So on your bike, instead of just having the none CA items of 17 to 20 that just vents the tank to the atmosphere , they do the charcol canistor at 21, so the evap fumes are controlled/absorbed by the charcoal canister isntead.
As for the chrome can under the arrow,
Note sure what is doing , if its part of the evap system to tie in both the float bowl vent and tank vent to the evap system, or it it was some kind of oil catch can system instead.
So on that note, if tank vent is piped into it then out the bottom to the charcoal canister, then port at the arrow, is where the carb float bowl vent goes to.
If line coming down to canistor is not going to the chrome smaller tank, but that line goes to the tank vent instead, then best guess is it was designed as oil catch can, but since your breather bolt are vented, not ported out, then chrome tank is not doing a thing, and the port that your pointing to with arrow, would have been for breather bolts porting to it with this kind of breather bolt set up.
