Fork question
Old Jan 9, 2025 | 04:12 PM
t150vej's Avatar
t150vej
Originally Posted by Dano523
Did not think of that, and if you remove bolt 12, instead side bolt 26 oil drain bolt to remove the fluid from the forks, forks need to come apart.
You can take the bottom bolt out and put it right back in but, it must have a new sealing washer.
Old Jan 10, 2025 | 08:37 AM
Dano523's Avatar
Dano523
Kind of, but the glitch is the oil that is going to be on the dampening rod threads, that the loctite is not going to bind to, to keep the bolt from backing out over time with their lower torque specs.
On the new factory bolts, they already have loctite on them to start with, while on reusing the old bolt you need to add some 242 to them isntead,
and this means that the bottom of dampening rod threads need to be clean and dry before you reinstall the bolts.
Old Jan 10, 2025 | 09:01 AM
johnod's Avatar
johnod
Walk in the part,
Star by removing 21 and up,
Now loosen tripple clamps to slighty drop the fork down to exspose the flats on 22,
tighen back up the lower clamp, to loosen 22, then you can drop the fork out of the triple clamps.
With fork loose, keep downward pressure on 22 as you thread it up and out, since you will have spring pressure on it from spring 33.
Once you have 22 out, turn fork over, to drop out spring 33 and flat washer on top of spring 24 into oil bucket, and allow as much oil to drain out as you can.
Now using impact gun and long allen bit, zip bottom bolt 12 and and make sure to pull the copper washer with it, then turn fork top side down to slide out 33-25 and 17
Now lift up rubber cap above 23 if forks have one on it, then remove clip spring 23,
Now grab lower tube18, and using inner sliding tube 32 like a slide hammer outward away from 22, you going to remove 32 with seal 31, and washer 29, bushings 35 and 30 that will come out with tube.
At this point, break out the cleaner to clean the tube and parts.
Now to reinstall using seal driver,
New 32 snapped on to end of 32, drop that down the tube 18 with a touch of fork on on both bushings, drop the bushing 35 on the tube and slide it down, install the washer 29 on the top with it dome edges upwards, then use seal drive to seat bushing 35 into 18. How lube up the tube, and drop seal 35 down the tube, then if you have an extra washer 29, can drop it top of the seal (number side up on seal) to drive the seal into place. Once seal is in place, then remove extra washer 29, and reinstall snap ring 23 and make its seated all the way into the tube.
Now on dampening rod 33,install spring 25, put 17 on end of dampening rod, slide the dampening assembly down the slider tube with it all the way down, then reinstall bolt 12 with new copper washer.
Note, use blue loctite on bolt threads if reusing the old bolts, and had tighten bolt down to start with to make sure 17 has not dropped off, and then can torque to spec. If dampening tube starts to turn as you are tighting bolt, send spring 34 down the tube to hold dampening tube in place with a little pressure on the spring.
At this point, install your fork oil to factory specs, pump the slider tube a few time up and down to get the air out, then drop spring 34 down tube 32, drop washer 24 on to of spring, and with 32 pulled upwards all the way, should have to compress the spring down about 1/4" in the tube, to start threading 22 on the top of the tube.
If you do not have to compress spring 32 to get 22 screwed back onto the top of tube, then stop, since you have an after market spring that is slightly shorter, and there should be a spacer that is used with the shorter spring on top of it between the the spring and washer, to get the required amount of spring preload to start with.
And again, like when you where removing the forks, install the fork in the tipple clamps just enough up so 22 flats are still exposed, tighten lower tripple clamp, and finish tightening 22 to top of tube, before you loosen the lower clamp again to install it all the way up.
https://youtu.be/fz2033CxBwc
As for air ride forks, the air pressure is used to set free sag ride height, and not so much dampening off the forks isntead. Again, spring should need to be compressed in tube, to get 22 cap threaded back on. As
As for fork oil, I use 15w in the forks to factory fluid amount, the drain the fluid out of the shocks, to replace that fluid to 10lbs at 10.5 oz per shock.
https://youtu.be/q1upvM7udd8
As for using drain bolt to change fork fluid, don't since forks need to be rebuild about every 30K, including pulling the forks apart to get all the old fluid out in the first place. Here is what 30K fork fluid looks like, and all is needs to be flushed out with fork rebuild, isntead of leaving any of mess behind to just be mixed with the new fluid.
Also, when cleaning up fork parts before reassembly, make sure to flush the void area between the inside and the outside of the tube as you can see on the left hand tube in the below photo.
The last one, if you do have a lathe handy, great to check to make sure tubes are not bent out of the spec, and give then a quick surface polishing as well.
Thanks, lots of info.
Old Jan 10, 2025 | 10:18 AM
t150vej's Avatar
t150vej
Just for the record, I don't care what all the you tube genius or the book says - replacing the fork seal and even slider bushings does not require removal of the fork. Do it right on the bike.
You cannot do the damper rings without taking the tops off, but I challenge anyone to show me some that were worn out, regardless of mileage.
Old Jan 10, 2025 | 10:45 AM
t150vej's Avatar
t150vej
Sorry Dano, I missed this post before going on my last rant.
The loctite is actually irrelevant. The copper washer seals they won't come loose 242 or none. The bolts can't come out for the axle anyway.
I do agree - they will drip seemingly forever just hanging there and new bolts come in the bushing kit and should always use new bolts.
Old Jan 11, 2025 | 10:38 PM
Max Headflow's Avatar
Max Headflow
You don't want to loctite on the damper bolts. The problem is that if you do the damper tube can spin the next time you try to loosen the bolt.. I've done it and know.. Besides that it's a good idea to see if the tube still moves freely after tightening the damper tube so it's not rubbing the sides. Sometimes I trim the bottom of the tube in a lathe to make sure it's square. I've also seen where not all the crud in the bottom of the tube was cleaned out and the damper cocked.
Old Jan 12, 2025 | 01:44 AM
Dano523's Avatar
Dano523
From the HD manual,
I 0. Apply a nonpermanent threadlocking compound to
the damper rod Allen bolt thread prior to installation. Insert
the Allen bolt (Figure 14) through the lower end of
the slider and thread it into the damper rod. Tighten the
bolt securely.
As for old loctite on the dampening rods and end cap spacers, that should have been cleaned up when you had them out, and were checking to make sure that dampeners are not bent as well.
16. Check the damper rod (B, figure 59) for straightness
with a set of V-blocks and a dial indicator (Figure 60), or
by rolling it on a piece of plate glass. Specifications for
runout are not available. lf the damper rod is not straight,
replace it.
I 8. Check the internal threads in the bottom of the
damper rod for stripping, cross-threading or sealer residue.
Use a tap to true the thread and to remove scaler deposits.
Old Jan 12, 2025 | 06:28 AM
Schex's Avatar
Schex
I’ve done it a few times. One wrap of packing tape on the bottom bushing groove of the tube and slide the seal on with no damage.
Removing the damper rod bolt with the spring installed keeps the damper rod from spinning, no loctite on the bolt for me either.
You can cut a hex key and use a socket on it for a long reach tool for the damper bolt if you don’t have a long hex socket.
Old Jan 12, 2025 | 07:50 AM
Max Headflow
From the HD manual,
bolt securely.
replace it.
Which manual?
Add: Haynes, Chilton or Clymer?
I have factory FLH 94 and 02. Neither say anything about loctite.
Old Jan 12, 2025 | 09:56 AM
t150vej's Avatar
t150vej
There ya go
