CVP accelerator pump nozzle
Old Jan 27, 2025 | 04:23 AM
Greaser1340's Avatar
Greaser1340
Default CVP accelerator pump nozzle
Anyone running one of these in your cv? I ordered one the other night whilst picking up a 46 pilot jet and some other bits and bobs to refresh my carb.
Seems to sit a lot lower down in profile and sprays a mist of fuel rather than the usual straight splurge of gas down the throat. Supposed to help the old cv pick up a lot smoother in the low rpms where they seem to be notoriously a bit groggy.
Anyone who uses one have any feedback good bad or indifferent?
Old Jan 27, 2025 | 06:30 AM
Chris_G's Avatar
Chris_G
I used it and happy with the results.
I purchased everything from CV including a new slide. BTW, I didn't notice any difference with the #46, went #48 as suggested on this forum.
Old Jan 27, 2025 | 06:56 AM
Greaser1340
Thanks for the feedback. Did you notice any improvement in smoothness when low rpm riding?
I've used a 48 before and didn't mind it but it was a little too fat for me. The 45 in there currently is decent once the motor warms up but needs 3.5 turns out which is too much. 46 should be a decent halfway house.
Old Jan 27, 2025 | 12:26 PM
t150vej's Avatar
t150vej
Does the bike need 3.5 turns to idle correctly or to behave at low speeds?
Is you're enricher (choke) cable working correctly?
Old Jan 27, 2025 | 02:48 PM
Chris_G's Avatar
Chris_G
Yes, great improvement!
The bike was sold due to carburetor back fire and poor fuel economy.
No more carb farts and 42 mpg, I'm happy.
Old Jan 28, 2025 | 12:50 AM
Greaser1340
yeah choke is all good. The motor has s&s jugs, 76cc heads, ev13 cam and drag pipes with khromewerks baffles so it needs a little bit more on the idle mix screw to feel right and get decent colour to the plugs. I run a stock slide, spring, emulsion tube, cvp velocity needle and a 185 main. Don't get me wrong, the 45 does the job but I thought I'd try the 46 seeing as I was already buying the new accelerator nozzle. I've run a 48 pilot which made starting / warming up a lot easier but it wasn't as punchy on the low end as the 45, hence hoping for a bit of a happy medium with the 46
Old Jan 28, 2025 | 10:52 AM
t150vej's Avatar
t150vej
OK. Thanks for the info.
You got a lot going on. Now I see why 45 might not take care of it.
Norm jr.
Carburetor Related
Apr 27, 2017 11:11 AM
Tileman2692
Dec 23, 2016 03:45 PM
krazy3
Exhaust System Topics
May 14, 2010 05:29 AM
bigzdogz
Shovelhead
May 9, 2010 08:10 PM
rc51ironhead
Ironhead
Jan 30, 2009 12:44 AM
