EVO being evil
Old Jul 17, 2025 | 09:56 AM
97SpringerResto's Avatar
97SpringerResto
I will try, wouldnt that be something if that was the total fix....
Old Jul 23, 2025 | 07:13 AM
97SpringerResto
Thanks Yankee Dog all of those suggestions are well recieved and i will examine those options. Thanks that paint had 5 layers to get back down to the original so down to metal and started all over. 3 months though i wasnt hurrying either
Old Jul 23, 2025 | 10:47 AM
Hey Man's Avatar
Hey Man
Originally Posted by Rains2much
Hey this may sound like too simple… but check your battery ground. I don’t care if it feels tight, remove, wire brush, reinstall and tighten. A ground can cause the very symptoms you’re describing.
Yup. Many folks that the ground is just as important as the hot!
Old Jul 28, 2025 | 10:06 AM
tar_snake's Avatar
tar_snake
If a lifter is/has gone bad, you'll hear a 'clack' sort of sound near whatever cylinder. My bike, a '97 FLSTC, one day suddenly without warning made this really *LOUD* SSSHHH sound as I was doing around 35 mph. The bike nor motor stumbled, nothing 'happened' other than that loud sound. Freaked me the hell out! I spent the rest of I think about 3 months trying to pin down what it was, where it came from, etc. At first I thought maybe the exhaust gasket blew out from one of the cylinders, and I was leaning toward it all being the front one as the noises coming later seemed to be from there.
Well, the bike *seemed* to keep running fine, still got the 45 mpg I was used to, still had also what *seemed* the same power. Just a loud-ish tick or 'clack'. I stopped riding it for about a month because being disabled I simply can't afford major troubles so the little things I try to take care of as quickly as I can.
Finally one day about a week ago, I couldn't stand it any longer and figured I needed to look at pushrods (S&S Quickie) and lifters. This was going to be hard for me with my bad back, but sitting in the p/u or in a car really, really hurts along with trying to get in or out of one...I *NEEDED* my bike back up and running!
So, out I go, in 95 degree F heat and 95%-100% humidity. An hour or two in that and I *had* to come back inside for the day after wringing at least a cupful of sweat from my t-shirt. I had to remove the pipes, of course, but both gaskets were fine. Eventually got to nose cone off and all looked fine that I could see just from looking inside it. Next, the pushrod covers - always a PITA putting back *ON*. Then got to taking the adjustable pushrods down ' They were all still locked, so it wasn't the pushrods. Got those out and got the gaskets for the tappet housings for when I put it back together. Magnets in place helped get the tappets and housings off a *LOT*. Took the first housing off and then the second. A day or two later I finally got around to taking the old tappets out (these were from my '98 FXD I got T-boned on). I got all four sitting on the rag and started to check them, then as I picked one up I heard a slight 'clack'. The axle needles had ground out of the wheel. The wheel moved on the axle and had a huge amount of movement. I'm lucky it didn't move a little further or the corners of the wheel and axle sides would have ground into the cam lobe. Here's where I made a super short video of it, you can see and hear the sound it made...if you read the stuff I put down, my page is NSFW if just reading it, lol... https://www.facebook.com/ig.natz.16
Fixed with new tappets, and wow, the difference was amazing! It must have been going out for a while, it just took time for that wheel to grind all the rollers down to nothing. Bike runs *much* better than it did, a little more power and sounds fantastic once again, like a goood ol' Evo should (with an EV13 cam, heh). I still have no idea why I'd hear a loud SSSSHHHH, but whatever it was, it seems fixed now, even the plugs looked fine. So anyway, it won't hurt to check pushrods and lifters, ya never know.
langwilliams
EVO
11
Feb 16, 2017 10:38 AM
cm1101
General Topics/Tech Tips
Nov 2, 2015 11:50 AM
rotherdrummer
Jan 27, 2015 10:34 PM
DeputyLoud
EVO
Aug 8, 2014 10:49 AM
In Memoriam Citoriplus
May 14, 2009 02:32 PM
