Throttle cables time!
Old Jul 29, 2025 | 09:02 AM
factorybuilt's Avatar
factorybuilt
Default Throttle cables time!
Good day gentlemen! It has been a long time for me to post but I check in to be sure the classic Harley world remains intact. 😎
I have a 1997 Ultra Classic, 80" Evo with the MM EFI and it is kicking after 110,000 miles.
I was doing my throttle cable lube and noticed a couple of strands on the cables were broke. I need to replace them of course but it seems to be a bit of an issue finding the correct cables. I have the thick Harley service manual but I do not have the parts manual. I was hoping someone might be able to share the actual part numbers with me. It has the MM EFI and that seems where it gets tricky.
Thanks in advance for the help! ?😎
Old Jul 29, 2025 | 09:28 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
These folks should have the cables you need and are as good or better than any other cable manufacturer.
https://www.barnettclutches.com/?srs...Sub1U48Ei6Ma4q
Old Jul 29, 2025 | 10:29 AM
Architect's Avatar
Architect
HD OEM Parts Finder:
Genuine Harley-Davidson OEM Service Parts | Harley-Davidson USA
  • 56327-96
    THROTTLE CONTROL ASSEMBLY Not Available
  • 56351-96
    IDLE CONTROL ASSEMBLY
Not sure if these are the right part #'s for MMI, looks like for carb. Maybe your local dealership can sort you out.
Old Jul 29, 2025 | 02:30 PM
14GuineaPig's Avatar
14GuineaPig
I think these are for the Ultra Classic Injected
56357-96 THROTTLE CONTROL ASSEMBLY FLHTCI, FLHTCUI
56358-96 IDLE CONTROL ASSEMBLY FLHTCUI
The 1997 Touring Parts Cataloj is available oh HD SIP
1997 HARLEY-DAVIDSON® PARTS CATALOG: TOURING MODELS | H-D Service Information Portal
Old Jul 29, 2025 | 07:45 PM
IBDAGRIZ's Avatar
IBDAGRIZ
Default Per Ronnie's site
56357-96THROTTLE CONTROL
56358-96IDLE CONTROL
On my 98RK, the EFI cables are the same as the carburetor version as I'm doing that right now.
Griz
Old Jul 30, 2025 | 08:02 AM
im's Avatar
im
Suggest ordering the little rubber boots that cover the adjustment bolts too.
Old Aug 1, 2025 | 08:02 AM
factorybuilt
Thank you gentlemen! I knew I could count on you! ?😎🙌
Old Aug 4, 2025 | 03:41 PM
tar_snake's Avatar
tar_snake
  • 56327-96
  • 56351-96
Meh...it's the same for my '97 Heritage Softail Classic. It's been that way for a few years at least now.
TwoBlue02
Dec 29, 2012 05:00 PM
Ultrachris
Feb 25, 2011 01:07 AM
steelhead
Jul 6, 2010 07:28 AM
jcboof
Feb 9, 2008 11:02 PM
Godfather86
May 15, 2007 01:17 PM
