Valve springs
Old Aug 2, 2025 | 10:49 AM
Dave0176's Avatar
Dave0176
Default Valve springs
In the process of a complete rebuild, my question is I want to replace the valve springs because they’re almost 30 years old and have 30 thousand plus miles on them. I’m running an Andrews EV46 which says stock springs. Stock is 18201-83 18202-83. I only seem to find them used or I see 18206-06 but that is saying for high lift high rpm. I’ve also seen the S&S conical valve spring kit, but it also is listed as high lift .585? So the question which one to get?
Old Aug 2, 2025 | 11:11 AM
IBDAGRIZ's Avatar
IBDAGRIZ
None. Nothing wrong with the ones that you have now. If you are really worried about them, then pull them and test them. 30k is nothing on a set of springs.
I'm running the 46 cam on a set of springs with 68k on them and nothing to worry about.
If you wanna go over.585 or so, then you can replace them for what you need.
If you just have to get rid of them, let me know and I'll take em off your hands.
Griz
Old Aug 2, 2025 | 11:16 AM
Dave0176's Avatar
Dave0176
Sorry made a typo I said 18206-06 I meant 18209-06
Old Aug 2, 2025 | 01:06 PM
t150vej's Avatar
t150vej
Another vote to stay with stock springs. Mine have 140k + and have never known a stock cam.
Old Aug 2, 2025 | 03:46 PM
Dave0176's Avatar
Dave0176
Well you guys are definitely saving me money thanks I stay stock.
Old Aug 2, 2025 | 03:51 PM
Dave0176's Avatar
Dave0176
My buddy who has a 10 second car and built his motor was the one who suggested replacing the springs because he said he replaces his after so many runs. But of course were talking racing vs street riding lol
Old Aug 2, 2025 | 03:56 PM
Dave0176's Avatar
Dave0176
I’m working my way to the heads right now I banging my head against the wall with swapping spacers trying to set the timkin endplay right.
Old Aug 2, 2025 | 04:15 PM
t150vej's Avatar
t150vej
Did you not buy the 9028 bearing?
Old Aug 2, 2025 | 04:19 PM
Rains2much's Avatar
Rains2much
I would do new lifters.
Old Aug 2, 2025 | 06:18 PM
Dave0176's Avatar
Dave0176
I did but endplay with that spacer had no clearance at all.
I made a slip fit sprocket shaft to assemble it without pressing and I had clearance, however after pressing the bearings in place which I understand is a 2 thou press fit you lose 1.5-2 thou so I figured I’m pretty close I just need the next two sized spacers and it should do it. 🤞
