Evo Ignition Coil
Old Aug 18, 2025 | 08:05 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Absolutely nothing wrong with dual fire, even on a built motor.. You won't feel any difference in performance..
Old Aug 18, 2025 | 08:17 AM
Racepres's Avatar
Racepres
Can't measure it either, on Racetrack.. Unless engine is Built with Dual Plugs for the Traditional Reasons.."Flame Travel"
Old Aug 18, 2025 | 05:33 PM
Dave0176's Avatar
Dave0176
AFAIK and what I’ve been told there is no difference in power, however the motor will run smoother with single fire and get less spits and sputters.
Old Aug 18, 2025 | 05:41 PM
98hotrodfatboy
Not so sure about that statement, but I will say if you wanted to run more consistent and smoother, get rid of the OEM rotor (timing cup). The OEM ignition rotor.. They do flex and get out of round.. I personally experienced it.. I bought the CNC aluminum timing cup from Hammer performance.. It's solid aluminum nice and solid..
I have a thread with pictures around here somewhere showing the damage to the cam position sensors (CPS), and it turned out that it wasn't the CPS. It was the oem timing rotor that was no longer round and was taken out the CPS..
Old Aug 18, 2025 | 05:55 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Someone told you a story...
My dual fire 1989 EVO, with stock ignition coil (that I have owned for 150,000 miles and 35 years) has never had "spits and sputters".
Old Aug 18, 2025 | 05:56 PM
Dave0176's Avatar
Dave0176
True about the rotor. I bought the Hammer Performance rotor it’s a machined piece of steel.
Old Aug 18, 2025 | 06:58 PM
Racepres's Avatar
Racepres
As Measured How?? I call Marketing Strategy BS
Spend more Money...Gotta be Better!!!!
Edit; Some Claim..that the sound difference can be distinguished.. if true... The Stock Dual Fire says "Giddyup, GiddyUp"
Stick yer Taters!!!
Old Aug 18, 2025 | 10:50 PM
Dave0176's Avatar
Dave0176
It was my local Indy that told me that years ago, of course he was a big pusher of the compufire ignition.
Old Aug 19, 2025 | 02:09 PM
Max Headflow's Avatar
Max Headflow
Sounds like someone smacked the rotor or it wasn't installed right.. That thing spins what 3500 max. My 113 used to run with a 7000 rpm rev limit.. Never an issue.. Maybe more on a hot sporty?
You sure the Hammer rotor was aluminum? I'd guess it'd work if the sensor was optical but I thought they were all Hall effect?
Old Aug 19, 2025 | 02:38 PM
pgreer's Avatar
pgreer
The only one I've see from Hammer Perf is machined steel. But that's not to say there isn't one.
https://www.1250kits.com/xlignition.shtml#timingcups
Paul
