Evo Ignition Coil
Old Aug 16, 2025 | 01:17 PM
bulldog1776's Avatar
bulldog1776
Default Evo Ignition Coil
97 Heritage Softail. It has the dynatek 2000i ignition on it, and it currently has the stock coil.
I'm wanting to replace the coil as i suspect it is starting to have a few issues at times.
Are these as simple to install as taking out like 2 bolts? anything else I need to know to do when replacing one?
Anyone have any thoughts on the comp cams coil as a replacement?
https://www.denniskirk.com/competiti...rd/2010173.sku
Thanks guys.
Old Aug 16, 2025 | 01:33 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The OEM coil is still available, $71 from the dealer.
The claim that it delivers more spark energy than the stock unit is BS.
Old Aug 16, 2025 | 04:03 PM
bulldog1776
ok thanks. and as far as installing the coil, is it just 2 bolts? anything else to do?
Old Aug 16, 2025 | 04:22 PM
Racepres's Avatar
Racepres
Long as same-same...No change.. drop in!!
Old Aug 16, 2025 | 05:50 PM
IBDAGRIZ's Avatar
IBDAGRIZ
Two bolts, two wires, and two plug wires. Assembly is the opposite of disassembly.
Griz
Old Aug 17, 2025 | 05:59 AM
guido4198's Avatar
guido4198
Easy installation for sure just pay attention to where the small wires go before you remove the one you have. FWIW and IMHO… unless you’re trying to squeeze every possible bit of performance outta your bike, stock coils are just fine. Even if you are, I’m not convinced there’s a significant gain from the aftermarket.
Old Aug 17, 2025 | 06:22 AM
RANGER73's Avatar
RANGER73
With the Dynatek 2000i, you can put in a single fire coil, it's just a matter of 1 switch on the Dynatek,
1 additional wire on the coil and making sure the plug wires are on the correct plugs.
So no more wasted spark.
But your way's definitely easier.
Old Aug 17, 2025 | 08:44 AM
Racepres's Avatar
Racepres
Easier plus, No Advantage to spending more on Single Fire.. Single fire is for Dual Plugs...and of course..Computer controlled Injection!!
Old Aug 17, 2025 | 09:16 AM
RANGER73's Avatar
RANGER73
How many plugs does he have, and WTF are you talking about, for computer controlled ignition?
He's buying a coil anyway, what's another $100.
Old Aug 17, 2025 | 10:06 AM
Racepres's Avatar
Racepres
Welp...I might spend More, to Not deal with Single Fire, on My Street Bikes!!
