Comp sprocket
Old Sep 4, 2025 | 06:25 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Hard to believe you would be able to hear a chirp from inside the primary.. I'd be look for something else up front that could cause it.. But if you have concerns about the comp sprocket, check to see that the teeth are pointed.. If so time to replace.. You should also check the chain for excessive wear..
Old Sep 4, 2025 | 09:31 AM
t150vej's Avatar
t150vej
Head gasket failure will cause a chirp, often quietening when warmed up. Up to a point of course.
hogvibrator
EVO
Apr 9, 2023 12:47 PM
mjpoerp
Milwaukee Eight (M8)
May 16, 2017 12:48 PM
chevdude
Jun 20, 2012 01:28 PM
jsw5555
Jan 9, 2010 08:41 AM
Lipper
May 16, 2007 10:17 AM
