My latest evo problem
Old Sep 4, 2025 | 05:48 AM
Hey Man's Avatar
Hey Man
Default My latest evo problem
My bike seems to be running a bit hot lately but I figured it was just 'cuz it's summer in Florida. But after about an hours ride on my POS 1993 Heritage Classic yesterday, when I got home I noticed the bike seemed awfully hot and the chrome cover on my rear pipe was starting to turn gold. I've checked for intake and exhaust leaks but found none. What else besides timing, could be causing this problem? If it is from timing do I need to advance or retard?
Old Sep 4, 2025 | 06:01 AM
98hotrodfatboy's Avatar
98hotrodfatboy
First off I would check the plugs to see if they are indeed running lean and then recheck ignition timing.. Then do you have an inferred temp gun to confirm? I think if timing is too far advanced it will create more heat, confirm that it's set properly then go to the carb or manifold leaks. Others say if it's too retarded it will create more heat but I'm not so sure about that.. I've never tested the difference..
Is there a difference in, intown riding compared to open road? Or does it matter...
Old Sep 4, 2025 | 06:25 AM
Bubba Zanetti's Avatar
Bubba Zanetti
My first thought was an intake leak, but you said you checked that. Did you check the carb boot for cracks?
Old Sep 4, 2025 | 06:39 AM
Schex's Avatar
Schex
Check VOES operation, not only switching for timing, but the diaphragm inside could create a vacuum leak.
Timing retarded enough could have the mixture burning in the pipe.
Could be running lean, you could try clearing the main jet by removing a/c, draining the carb bowl, spray some brake clean down the main nozzle emulsion tube followed by compressed air.
Old Sep 4, 2025 | 07:06 AM
Racepres's Avatar
Racepres
Yes...Retarded timing causes excess Heat... lots of it if severely retarded.. BTDT on a Mistake.
Intake leak will also (lean mix) but usually manifests itself in much more noticeable Problems First! Obstruction of cooling air possibly, ...Sidecar comes to mind!! had that also.. Very poor oil Flow can cause excess heat, ...tho in general, if the Lifters don't Clatter (assuming Not Solids) low flow is Doubtful, (Not Impossible).
Oil Temp Gauge???
Old Sep 4, 2025 | 09:39 AM
t150vej's Avatar
t150vej
You have an intake leak period. If you are determined it's a pos,then get rid of it and tell whoever ends up with it that it has an intake leak.
Old Sep 4, 2025 | 10:46 AM
RANGER73's Avatar
RANGER73
After checking for an intake leak, check the nose cone and make sure the pick up hasn't moved.
Old Sep 4, 2025 | 04:44 PM
Yankee Dog's Avatar
Yankee Dog
And post pics of your plugs. A heat gun is pretty cheap nowadays, it's a good suggestion and a great tool to have. The only issue I have with them is they don't like (not accurate) on shiny surfaces.
Old Sep 4, 2025 | 04:50 PM
Hey Man's Avatar
Hey Man
Plugs look good though the rear plug was a bit lighter than the front.
Old Sep 4, 2025 | 04:53 PM
Hey Man's Avatar
Hey Man
Not yet but I will tonight.
