Spark plug question
Old Sep 29, 2025 | 06:49 PM
Dave0176's Avatar
Dave0176
Default Spark plug question
Since I’m running the 10.1 piston would anyone recommend running a colder plug. Currently I have a NGK BPR5 wondering if going to the 6 is better for the engine? Just a thought guys
Old Sep 29, 2025 | 07:23 PM
Ohio HD's Avatar
Ohio HD
Stock heat range is fine. Street ridden bikes seldom see any need for changing the heat range. In any case I assume that you have changed the camshaft as well. So the corrected compression (which is the important compression value) may be same or even less than a stock motor.
Old Sep 29, 2025 | 08:18 PM
son of the hounds's Avatar
son of the hounds
You ought to be able to read your plugs after 1000 miles. A really good reader could diagnose at 500, but it takes me a while to really understand what the plug is telling me. Don’t jump until you know what the issue you want to resolve is, then correct gap, plug, or map.
Old Sep 29, 2025 | 08:33 PM
Dave0176's Avatar
Dave0176
I just realized the BPR5ES-11 plug comes gapped at 0.44 thou so I guess I’ll pull the plugs are regap at 0.40
Old Sep 29, 2025 | 08:34 PM
Dave0176's Avatar
Dave0176
Btw it’s running fine just diving deep into tuning
Old Sep 29, 2025 | 08:35 PM
son of the hounds
smart move, gap first, the ride, then analyze.
Old Sep 30, 2025 | 07:19 AM
98hotrodfatboy's Avatar
98hotrodfatboy
The BPR5ES-11 is one of the best plugs for a modified Evo, the Autolite is also very good.. Gap to .038" for 10:1 comp and the EV 46. What jets you running in the S&S E?
Old Sep 30, 2025 | 08:19 AM
Rains2much's Avatar
Rains2much
For plug gap I run hard all the way to 5th gear at around 5,800-6,000 rpm. If the motor did not cut out… I widen the gap until it does cut out.. then I close the gap 2-3 degrees and retest for no cutting out. I run between 50 & 55 thou gap on the soft tail and 48-50 on the Road king.
I test coils this way as well. After thousands and thousands of dollars spent on industry hyped ignitions I truly believe the Dyna S with a 90 OEM coil from Harley is the hottest fatest spark you can have under a consistant load. Oddly I only have it in the Shovel. I’m running the 2000i in the EVO’s with a quality 90’s style three post coil.
Old Sep 30, 2025 | 08:49 AM
Dave0176's Avatar
Dave0176
The jetting I haven’t touched, its what came in it from S&S.
SchnauzerNamedGator
2014-2024 Touring Models
18
Jun 20, 2022 07:55 PM
cgmartine
11
May 24, 2021 11:07 AM
jackhis
Aug 12, 2019 11:09 AM
jbyun
Aug 11, 2019 10:07 PM
guild
Jan 16, 2008 07:31 PM
