How do you regap a Iridium Spark plug?
Old May 4, 2011 | 01:42 AM
jackhis's Avatar
jackhis
Default How do you regap a Iridium Spark plug?
I know this is so amateur question, but I have never done this before, and I really don't want to damage the "very tiny" head of this spark plug.
So, what is the best way to regap without damage the plug? Tools?
Thanks much in advanced!
Nick
Old May 4, 2011 | 02:58 AM
emwolb's Avatar
emwolb
i don't think you can re gap them. that's why most guys are using autolite or harley plugs. they work just fine and are a whole lot cheaper than the iridiums.
Old May 4, 2011 | 03:35 AM
8blkfxdb's Avatar
8blkfxdb
Buy a new one you cheap ***! You only need two! Just check before you leave the parts house and make sure its right...
Old May 4, 2011 | 05:44 AM
dohadex's Avatar
dohadex
Exclamation Whaaaaaaat?
You NEVER re-gap Iridium plugs! They will last a minimum of 25k miles. Put them back in and ride!
Old May 4, 2011 | 06:19 AM
jackhis's Avatar
jackhis
That's how you assume everything with your little brain!
How do you know these are used, and how do you know that they are in spec.?
I just recheck my OEM spark plugs, and they are less than 0.034" which is way out off spec, and they are just 12K miles old. Go figure!
Don't assume that they are old, when I say "regap".
The manufacturer has already gapped the plugs, but just in case they are out of spec., then what!
Old May 4, 2011 | 07:13 AM
nvsteve's Avatar
nvsteve
Use a side gap tool that does not contact the electrode.
Old May 4, 2011 | 07:24 AM
coolerman69's Avatar
coolerman69
I've been told by more than one wrench not to use those plugs.
Old May 4, 2011 | 07:52 AM
RollaMo's Avatar
RollaMo
Out of all the responses to this thread, this is the actual answer to the question being asked.
Old May 4, 2011 | 07:57 AM
JayStronghawk's Avatar
JayStronghawk
Side gap tool and Feeler Gauge Most iridiums come with around a .035 Gap so is easy to expand a little with a Feeler .. be gentle and take your time they are too damn expensive to screw it up
Old May 4, 2011 | 09:26 AM
The Q's Avatar
The Q
I check and gap my NGK iridium plugs just like a stock plug with a spark plug wire type gap tool. Just becareful about the tip of the plug.
