Noise from primary
Old Feb 16, 2026 | 06:06 PM
jimkav's Avatar
jimkav
Default Noise from primary
Any idea’s what would cause the noise and the damage to outer primary cover (see attached)
bearings look ok/nothing visible.
could not move the shaft after pulling clutch hub.
anyone?
Old Feb 16, 2026 | 06:19 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Year and model of your motorcycle would be useful.
Do not see any damage to the primary.
Old Feb 16, 2026 | 06:47 PM
t150vej's Avatar
t150vej
Is the transmission in neutral?
Old Feb 16, 2026 | 07:25 PM
jimkav's Avatar
jimkav
85 flht sorry
Look at the 1/4 moon cut where you see the orange peaking out.
Old Feb 16, 2026 | 07:29 PM
jimkav's Avatar
jimkav
I’ll check it when I take it back apart.
i just inspected & didn’t see anything
obviously wrong except the cut in primary.
put most of it back together as it was for now.
Prob strip back down over the weekend.
thanks for the suggestion/make sure it’s in neutral!
Old Feb 16, 2026 | 07:49 PM
Tommy C's Avatar
Tommy C
Make sure that you get the key firmly seated in the keyway on the mainshaft or you will split the flange in the clutch hub.
Old Feb 17, 2026 | 06:37 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Is this what youre talking about?
Old Feb 17, 2026 | 09:50 AM
t150vej's Avatar
t150vej
That dip in the circle is normal but he may be seeing rubbing that we can't see.
Old Feb 17, 2026 | 10:03 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
It`s hard to get an idea of what is pictured when the camera is one inch away.
Model and year?
Is that a copper washer?
Old Feb 17, 2026 | 10:51 AM
Tommy C's Avatar
Tommy C
Model and year?
If the bike is an 1988 or earlier, that copper washer is the thrust washer for the pinion gear.
