Slow turning over
Old Feb 28, 2026 | 12:15 PM
glidein wide's Avatar
glidein wide
Default Slow turning over
Hey friends, what's the best way to determine if I need a new battery already, 3 years old or if my starter motor is on its way out, it was dragging on cold days last year also. 86 wide glide, 20/50 oil
Old Feb 28, 2026 | 12:26 PM
Joe12RK's Avatar
Joe12RK
Measure the voltage across the battery when cranking. If it drops below 9 or 10v it is shot. I may be wrong about the voltage?
Old Feb 28, 2026 | 12:42 PM
MURPHCC1's Avatar
MURPHCC1
Thats about right, why not take it out and have it load tested?
Doesn't cost a thing at auto stores.
Old Feb 28, 2026 | 12:50 PM
Racepres's Avatar
Racepres
An 86 FXWG??
the 4 speed with kicker?
mine has that age old 4 speed starter.
not the most powerful.
requires a tested Good Battery
and sometimes new/rebuilt, solenoid
Old Feb 28, 2026 | 01:15 PM
glidein wide
Because we just had blizzard now 55° out with a massive mud pit to get out 😆oh you probably mean take it out of the bike 😆 I guess I can do that 😉
Old Feb 28, 2026 | 01:56 PM
MURPHCC1's Avatar
MURPHCC1
yup, take it OUT of the bike........lol
The battery that is..........lol
Old Feb 28, 2026 | 03:53 PM
Yankee Dog's Avatar
Yankee Dog
If battery checks out to be OK, then next suspect is connections, cables, and copper solenoid contacts. Would not hurt to replace the 5 pin relay as well. While brushes could cause slow cranking, that would be way low on the list of things to check. Sometimes it's the start switch, but that is usually is a no turnover situation.
Old Feb 28, 2026 | 09:55 PM
HarvHD's Avatar
HarvHD
Also, if you're able to get jumper cables connected to your battery from a known good battery (eg your car), and it turns over quickly, you've narrowed your problem down to a weak battery (which could be due to a tired battery or a charging system that isn't keeping up) or poor battery connections.
I agree with the other posters, your starter isn't the most likely culprit.
Old Mar 1, 2026 | 05:25 AM
guido4198's Avatar
guido4198
I feel like I’m piling on here but to add a little emphasis to the previous excellent suggestions, I’ll reiterate that the starter is waayy down on the list of causes for your problem.
Battery itself is always first. I don’t even trust a factory new battery, having gone that route when my bike was exhibiting startup issues only to find, when the problem persisted…the new battery had a bad cell 😵‍💫😡. Of course, that was only after acquiring several new parts that weren’t needed after all. Just like me, you’re dealing with an older ( mature) motorcycle. Mine’s an ‘85. Aging cables, wires, grounds are always suspect.
Old Mar 2, 2026 | 06:33 AM
Racepres's Avatar
Racepres
The Bosch relay is a Go/NoGo device.. if it "comes-in" it is Good..
Best is to simply jump small screw to long screw at solenoid in this situation..as this eliminates all but the solenoid..and of course..Battery... as stated...New Batteries are even suspect...
I have Not finished the wiring on my '86 FXWG, too lazy...Been starting it with a casino coin at the solenoid for 2 years!!!
