Thread Sealant Quick Question
Old Apr 23, 2026 | 04:02 PM
NorthWestern's Avatar
NorthWestern
Originally Posted by MURPHCC1
Brake fluid destroys Teflon tape, possibly getting in the the system itself and wreaking havoc in there.
Yeah, I like Leak Lock. If you have access to some, it works on just about everything
Old Apr 23, 2026 | 04:21 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
As long as the teflon tape is on the threads and not off the end it will be fine.
Old Apr 23, 2026 | 04:46 PM
Max Headflow's Avatar
Max Headflow
Got an example?
That is what AI says but if I google thread tape for pipe thread brake fitting I get Teflon tape..
If you look at the first thing AI found for me, you get ...
AI search:
http://www.classic-motorcycle-build....-fittings.html
The guy is trying to seal brake flairs.
What about this? Teflon lined brake line..
https://shop.redline360.com/products...ded-hose-black
One guy says the fillers in Teflon tape causes the issue.. There aren't any fillers.. It's 100% Teflon.
AI does it again.
Old Apr 25, 2026 | 06:55 AM
98hotrodfatboy's Avatar
98hotrodfatboy
As a Steam Fitter A for many years, either is fine.. One needs to remember that Teflon Tape or Dope is primarily a lubricant to help with locking the male and female threads together to prevent leaks..
Old Apr 25, 2026 | 07:07 AM
Rains2much's Avatar
Rains2much
They make gas and brake resistant tape. It’s what I use.
Nick Sorgio
Shovelhead
Oct 4, 2020 02:48 PM
BelchFire
Aug 22, 2018 11:49 AM
nanaimohd
EVO
Jul 17, 2014 06:22 PM
06Sporty75
Mar 29, 2014 12:34 PM
bikehunter
Sep 4, 2010 12:46 PM
