Rear Brake Light Switch
Old Aug 22, 2018 | 07:04 AM
BelchFire's Avatar
BelchFire
Question Rear Brake Light Switch
My rear brake isn't triggering the light; it's the switch. On searching the forum I find that it's a common problem and the HD switches are short life money makers for the dealers. So, on advice from this post, I'm going back with a Napa SL147SB switch. My question to you guys: I know very well that I'm not supposed to use PTFE tape on any flared or other hydraulic fitting, but this switch has a common 1/8" NPT thread on bottom; do I use tape or sealant on the switch or do I just crank it down enough that it doesn't leak?
Old Aug 22, 2018 | 09:04 AM
frankjc's Avatar
frankjc
I used teflon tape on both my Super glide and my Sportster. No leaks on either.
Old Aug 22, 2018 | 11:49 AM
BelchFire's Avatar
BelchFire
That's good to know, Frank; thank you. Inasmuch as it's a NPT, it should require a sealant; inasmuch as it's a brake fitting, I'm hesitant. Knowing you've done it, I'll be very, very careful with the tape and seal 'im right up. Thanks!
fish-r-ride
Apr 25, 2021 12:42 PM
sidewayzls1
Sep 16, 2013 10:16 AM
joe1958
General Topics/Tech Tips
Feb 25, 2013 09:17 AM
Green Machine 04
Oct 5, 2010 02:34 PM
pistole
EVO
Feb 8, 2010 06:20 AM
