Front end too soft
Old Sep 16, 2007 | 09:54 AM
davp22's Avatar
davp22
6th Gear
Default Front end too soft
I just had the stock springs put back in the front end.... but it's too soft. Is there any way to adjust these to make it a little stiffer??
Old Sep 16, 2007 | 12:34 PM
JB's Avatar
JB
Default RE: Front end too soft
Go to a heaver grade of front shock oil
Old Sep 16, 2007 | 09:24 PM
ruger44's Avatar
ruger44
You might try adding a spacers, pvc pipe works well 1" to 1-1/2" length.
Old Sep 17, 2007 | 11:39 AM
fxstcguy98's Avatar
fxstcguy98
I would use the SE heavy fork oil, works great.
Old Sep 17, 2007 | 04:27 PM
davp22's Avatar
davp22
6th Gear
Is this something that is fairly simple to do?? And the SE oil.... is this something I would get at a Harley dealership, or is it just an off-the-shelf type oil? (sorry.. really new to this)
Old Sep 17, 2007 | 06:15 PM
darylnj's Avatar
darylnj
maybe you want to try progressive springs
i have them in my 94 fxds with se oil, it's nice and firm.
Old Sep 17, 2007 | 07:09 PM
Punky Brewster's Avatar
Punky Brewster
ORIGINAL: fxstcguy98
Yep
Old Sep 18, 2007 | 11:51 AM
fxstcguy98's Avatar
fxstcguy98
SE is Screaming Eagle, and yes you can get it at the dealer. There are other aftermarket types you can use, but I don't know the weight of the SE heavy off the top of my head. Changing is fairly simple, get a shop manual to walk you trough it, it will easily pay for itself they a like $45 through Zanottis HD.
Old Sep 19, 2007 | 10:19 AM
mp's Avatar
mp
ORIGINAL: darylnj
Listen to this guy. He knows whereof he speaks.
I put on Progressive fork springs 3 yrs ago. They will solve your front end problems. They cost less than $100 back then.
Old Sep 21, 2007 | 11:12 AM
JakeSabre's Avatar
JakeSabre
Get 2 1" OD nuts, get 4 1" OD washers or whatever size will fit inside your fork tube top), put 2 washers on either side of the nut,and superglue one washer to the nut. Leave the other one loose to aid installation. Put thesandwich on top of your fork spring and re-install your fork cap. Cheapest fix for soft forks.
[IMG]local://upfiles/31141/6A50327815064E07B4774190508C5B49.jpg[/IMG]
Talldog
Aug 10, 2014 07:26 AM
FL-kruzen
May 3, 2013 04:30 PM
bbgeo1
Oct 31, 2011 10:00 AM
Stickman53
Mar 13, 2011 09:49 PM
devils haircut
Dec 22, 2008 05:17 PM
