Different Evo Pumps
Old Nov 27, 2007 | 03:24 AM
justlookin's Avatar
justlookin
Stage III
Default Different Evo Pumps
Is there a modification that can be done to the oil pump 1992 so it will fit 1991 and down.It shows the bolt pattern is a bit different.Can i modifie bolt holes to fit older block 1988.Not sure if the oil routing is different.I am just new at this thing but willing to listen. If not i guess a new is on order.
Old Nov 27, 2007 | 04:20 AM
pajoe's Avatar
pajoe
Default RE: Different Evo Pumps
I can't answer your question but have seen a drilling guide sold by after market places such as Dennis Kirk to fit performance oil pumps to older models, the guide it is not needed for newer models. My guess is with the guide you may be able to drill the needed holes. Let us know for sure, I have a '90 and considering upgrading the oil pump.
Old Nov 27, 2007 | 07:25 PM
Pilgrim's Avatar
Pilgrim
Get a replacement from S&S; it's a better pump. You might even be able to talk to someone there about it when installation time comes.
Pilgrim
Old Dec 20, 2007 | 07:12 PM
nzbernie's Avatar
nzbernie
When i rebuilt my engine i got anS&S HVHP pump for my motor (1988 FXRS) excellent oil pressure hot or cold
i highly recommend one of these pumps
Bernie
Old Dec 21, 2007 | 07:41 AM
dog155's Avatar
dog155
I agree with the last couple of posts.The S&S pump is just what you are looking for.
Old Dec 21, 2007 | 07:42 AM
TIPN8R's Avatar
TIPN8R
^^^ I agree also. I just rebuilt my motor, and used an S&S pump, truly a quality pump!
Old Dec 21, 2007 | 08:33 AM
Dr.Hess's Avatar
Dr.Hess
That drilling guide may be to drill the extra hole on Shovelheads to use the later pumps. The extra hole is up at the top. I had to drill it by hand when I replaced the pump on a 79 because you couldn't find a jig anywhere in the mid 80's when I did it.
sisco683
EVO
Nov 6, 2017 05:35 AM
Fritzwm
EVO
Aug 10, 2012 08:16 AM
heavyd1951
Shovelhead
Jan 12, 2012 04:55 PM
LOWRIDER 65
Jun 10, 2009 10:17 PM
strange1
Oil Archive (no new posts)
Mar 31, 2008 09:51 AM
