Evo oil pump Question
Cheers,
Fritz
On the stock pump covers, the outlets are different also, though most aftermarket pumps allow for either configuration.
If you are considering installing a stronger bypass spring or adding shim to the same to increase oil pressure - I highly recommend against that. A stock oil pump will produce as much volume and pressure as ANY aftermarket pump. There is a technique to bring them back to factory specs, or better, so long as the gears are OK and the inner housing is not badly scored.
Cheers!
Fritz
