hyper charger??
Old Mar 10, 2008 | 04:00 PM
92Fatty's Avatar
92Fatty
Default RE: hyper charger??
I have had one on my 92 since i got it. Only problem i had was original breather grommets would come loose. I changed to a screaming eagle breather bar and no problems since.
btw Jake where did you find the breather assembly on your bike? I was wanting to change my setup to like yours. Any tips. I was just trying to find a backing plate and cleaner that just bolted to the carb since the h\c bracket and se bar work good currently. I just wanted a new breather. Kent
Old Mar 11, 2008 | 03:25 AM
Grimpy's Avatar
Grimpy
HCs look good on some bikes,on others,it just don't belong.
Had one myself.....it's now trotline weight....really,it is,no foolin.
Old Mar 12, 2008 | 07:53 PM
94Tourguide's Avatar
94Tourguide
6th Gear
I got Hyper charger on my 94 Ultra. I gained a little bit of powerin the mid range with the hyper charger over the stock air cleaner. I got mine from the want ad on this forum. For the money, it was worth it. Plus I like the looks of it.
Old Mar 12, 2008 | 09:43 PM
melnikmd's Avatar
melnikmd
The Fatboy had one on it when I bought it, and I had the Big Sucker on the last one. I think both are comparable as far as performance. I did like the sucking sound the Ness made when you goosed the motor, and if this bike didn't come with the Hyper charger I would have gone with the Ness again.
Old Mar 13, 2008 | 12:27 PM
gottahavvitt's Avatar
gottahavvitt
Thanks for all the replies. I just got a Hyper charger in a trade with a guy here on the boards and I guerss I am going to give it a try.
What kind of element do they use?
Old Mar 13, 2008 | 12:36 PM
gottahavvitt
test Can someone tell me why my pic is not showing up as my signature?????
[IMG]local://upfiles/48697/1A32FC23DCB34E9BBE403AF0B010A3EE.jpg[/IMG]
Old Mar 13, 2008 | 01:54 PM
92Fatty's Avatar
92Fatty
When you insert the code first hit the apply button then wait a few and hit the ok button. You must hit the ok button. Trust me it took me a few tries and searching posts to finally get it in. 500x250 is max size and 100k limits preferred. Kent
Old Mar 14, 2008 | 06:52 AM
gottahavvitt
Thanks Fatty! I have done all that and still no go. The address works fine but just won't show up in the post. Probably an AOL problem!
Old Mar 14, 2008 | 02:41 PM
92Fatty's Avatar
92Fatty
This time swap it out for
i checked mine and that is how it finally worked
Rigid evo is that a Paughco frame? btw there are no pipes on that bike.
Old Mar 14, 2008 | 02:52 PM
gottahavvitt
ORIGINAL: 92Fatty
I know there are no pipes. The day this pic was taken was its birthday and we weren't quite done yet.
Here is a pic with pipes. Acouple years later after I got t-boned by an old lady with blinders on. I think it was 1986. Yes it is a paucho frame.
[IMG]local://upfiles/48697/EEC8A5ACB9AD4E17B2C8AA8796645A6E.jpg[/IMG]
cvaria
Apr 23, 2013 07:52 PM
jojo2dog
Feb 6, 2013 11:03 PM
FenderGuy53
Aug 18, 2011 10:22 AM
Subcomandante Marcos
Exhaust System Topics
Aug 31, 2009 10:14 AM
maineultraclassic
Nov 7, 2006 10:56 PM
