Engine missfire
Old Apr 26, 2008 | 08:33 PM
mpete's Avatar
mpete
3rd Gear
Default Engine missfire
Engine missfire got progresively worse. Replaced plugs, leads. would run on 1 cyl, pull lead away from plug,run fine on 2 cyl. Stock ign system. compressiion good, new intake gaskets, carby cleaned, voes working properly. Coil, pickup, wiring and module test OK as instuctions in manual. Fit new plugs run good. 3 mile ride in city to work, after 2 days starts to missfire again. Check plugs and clean (only fine deposits normal for unleaded fuel) runs good for couple of days again. Pinpoints to weak spark but coil tests within specs. Tried heating pickup and module with no difference.Idont think it is heat related, if bike is parked and then started next day still has missfire untill plugs are cleaned again. Starting to suspect module.any ideas would be appreciated.
Old Apr 26, 2008 | 08:37 PM
t150vej's Avatar
t150vej
Default RE: Engine missfire
What year bike?
Old Apr 26, 2008 | 09:18 PM
mpete's Avatar
mpete
3rd Gear
Sorry about that, 99 evo, dual fire ign system
Old Apr 27, 2008 | 01:54 AM
RICHE's Avatar
RICHE
Sounds like the module to me.Sometimes you just dont know for sure.Throw some parts at it.
Old Apr 27, 2008 | 08:26 AM
jhnmflr's Avatar
jhnmflr
Agree , new module should do the trick
Old May 6, 2008 | 07:24 AM
mpete's Avatar
mpete
3rd Gear
Fitted a Screamin Eagle module tonight. Forecast for rain in Adelaide for the next few days, hopefully I can go for a ride on the weekend.
Crimson King
16
Feb 9, 2017 12:45 AM
Daniel Miller
Jul 7, 2015 09:06 AM
LeFat1
May 15, 2013 03:16 PM
zenwarrior
May 19, 2007 11:21 AM
Dworrakk
Apr 4, 2006 12:07 AM
