Evo clutches
Old May 22, 2008 | 05:10 PM
Harley_Dude's Avatar
Harley_Dude
Default Evo clutches
I know the clutch set ups changed from 1984-88 to 1989-1993 and again for 1994 and up. On the difference between the 1989-1993 to 1994+ change, what is the difference? Just the jack shaft and the ring gear? Any help is appreciated.
thx
Old May 22, 2008 | 07:13 PM
89 FXRS's Avatar
89 FXRS
Default RE: Evo clutches
I know that I am not much help but my 89 FXRis a differant clutch than a freinds 90 FXR. The differance that i could see is that he neededa special tool to remove his clutch where mine just unbolted. His was also easier on the hand to use. The plates are simular.The 90 is also a wet/dry clutch.
That is as much help as I can be.
Old May 23, 2008 | 06:53 AM
dog155's Avatar
dog155
Go to most any clutch dealers web site and there should be info on the differences.Barnett for example!
Old May 23, 2008 | 11:00 AM
Harley_Dude
Thanks Dog! Trying to sell a chopper that's not mine and want to make it as complete as possible. I think the only diff between the 1989-93 and the 1994+ is the jackshaft and the ring gear on the clutch but am not 100% sure.
Old May 23, 2008 | 06:51 PM
IronButt62's Avatar
IronButt62
Didn't the primary gearing change in 94 as well?
93 down 24/37 94 up 25/36 or something like that. Basically, 94 up get a slight reduction in RPM at speed.
Deet
Old May 24, 2008 | 08:06 AM
sqdealgeorge's Avatar
sqdealgeorge
The inner primary did change in 94 and up ( starter jack shaft hole size)
Old May 24, 2008 | 08:15 AM
dog155's Avatar
dog155
Yes, the comp sprocket went to 25 teeth,the inner primary difference Evo to Twincam, is the transmission bolt holes,are slightly different.
slim jim 1954
Aug 31, 2013 03:57 PM
slim jim 1954
Aug 23, 2013 05:57 PM
TSD
Jun 22, 2013 06:13 PM
TexasBikeBoy
EVO
Jun 23, 2012 10:34 PM
bobbsterkid7
Aug 2, 2007 02:01 PM
