Parts Swapping
Old May 24, 2008 | 07:59 PM
marecycling's Avatar
marecycling
Default Parts Swapping
I was hoping to get a good tip on the best way to tell if certain parts from different models and years will fit my 1996 FLSTF. Is there an easy and accurate way?
Old May 24, 2008 | 11:16 PM
pococj's Avatar
pococj
Default RE: Parts Swapping
Which "certain" parts?
I'm pretty sure a acetylene headlight from 1909 won't fit without a little re-working.
Old May 25, 2008 | 02:56 AM
Ribcracker's Avatar
Ribcracker
like wise I think some minnor work is requiered to fit a `02 duce in a wla45
Old May 25, 2008 | 06:24 AM
tobyhd1's Avatar
tobyhd1
You could get a HD accessory catalog and check out the "multi-fit" items and see what might cross over to your bike in the same "family" of bikes.`96 to `08 might not give you much .Evo/TC for one thing.Axle/wheel components are probably a no go unless you change out things in a wholesale manner.Get an aftermarket catalog and look up an item you would like and see how it`s listed and they will most likely state the years that it will fit. Then you can draw your own conclusions.Toby
Old May 25, 2008 | 11:17 AM
dog155's Avatar
dog155
Most parts from the 90's on up will swap.When TwinCams came along inner primary's and the obvious things are different.
Old May 27, 2008 | 09:08 AM
twowheelsforever's Avatar
twowheelsforever
A lot of parts from 84 to 99 Softails are interchangeable (for example, I just put a 99 fatboy rear fender on my 93 FXSTS)...
Recan
Nov 10, 2017 05:33 PM
roy micks
May 11, 2014 11:11 PM
Slimshadey
Dec 6, 2013 02:03 PM
larry harding
Knuckle Head
Jun 17, 2008 06:46 AM
oscarg
Dec 26, 2006 08:54 PM
