Exactly what I had mentioned.
Install a hela coil and repair those damaged threads.
Problem solved.
ORIGINAL: Fritzwm
Well, talked to the wrench today. He says one of the bolts has pulled out of the engine case. The last time it pulled a couple of threads so he locktited it. It evidently did not hold, RATS!!!!!!!!!
helicoil both bolts, so you don't have to go back in like I did when the second one pulled.
Look for any grooves worn into the gasket surface on both the head and cylinder even though the faulty stud threads have been found.....if a head gasket leaks enough a groove can get cut into either surface.
