damage from misadjusted pushrods?
Old Jul 7, 2008 | 10:56 AM
jokenroll's Avatar
jokenroll
Default damage from misadjusted pushrods?
Can't believe these epic failures! I guess I shouldn't consider myself "an experienced home mechanic" anymore
I've adjusted pushrods on a freshly rebuilt '94 evo, after a thermal break in, when I noticed a loud tappet noise.
I made them nice "finger tight", totally forgetting about bleeding the tappets. As a result I had tappet pistons all the way up.
So, when the engine is cold, they run nice and quiet, but as it warms up, the tappet noise gets definitely way too loud.
To make the matter worse, I've done 100 miles like that, wondering what the hell is the noise about.
So, my question is: should I look for some damage at this point, or should I simply adjust them properly, and then if I don't hear anything suspicious anymore, just assume that everything is fine?
Old Jul 7, 2008 | 11:24 AM
4x4Given's Avatar
4x4Given
Default RE: damadge from misadjusted pushrods?
Certainly, you should attempt to adjust them according to the specific pushrod manufacturer's instructions.&nbsp\\; If this cures the noise, count it as an inexpensive lesson learned.
Old Jul 7, 2008 | 01:09 PM
Buddy WMC's Avatar
Buddy WMC
If it was my bike, I'd pull the pushrods&nbsp\\;out to make sure they were not bent. I would then turn the engine over looking to&nbsp\\;make sure that the lifters were pumped up.&nbsp\\;I agree with 4X4's advice, then readjust to the specific specs on your pushrods.
&nbsp\\;
My way is a little more work and time consuming, but it insures that everything is right and done correctly. Make sure to allow enough time for the lifters to bleed down on the front cylinder before starting on the rear. If all goes well then lesson learned. If not, then maybe a lifter or two has collapsed and needs to be replaced. Good luck with your decision and keep us posted.
Old Jul 7, 2008 | 06:35 PM
dog155's Avatar
dog155
Default RE: damage from misadjusted pushrods?
As long as they were making all kinds of noise there should be very little wrong with anything.Just adjust them correctly and enjoy.
Old Jul 7, 2008 | 06:42 PM
2005UltraNC's Avatar
2005UltraNC
Also agree, you would know if you had it really out (either the rod would have fallen out or bent a rod).&nbsp\\; Adjust and ride on.
Old Jul 8, 2008 | 11:39 AM
t150vej's Avatar
t150vej
If you rode 100 miles and it wasn't missing due to a bent rod, simply properly adjust and you'll be fine.
Old Jul 9, 2008 | 02:40 PM
jokenroll's Avatar
jokenroll
Thanks a lot, gentlemen!
that what it was - no damage, and proper adjustment did it!
Pothole914
Mar 26, 2016 06:36 PM
JONNIEROCK
Dec 30, 2013 06:35 PM
TedMan
Exhaust System Topics
40
Apr 16, 2010 01:12 PM
97classic
EVO
Jul 14, 2009 02:17 PM
DOGKILLR
Jun 29, 2008 08:13 PM
