castle nut cotter pin rear wheel
Old Jul 28, 2008 | 09:45 AM
noreastermma's Avatar
noreastermma
Default castle nut cotter pin rear wheel
I installed a rear wheel on my 96 FLSTF Fatboy which had 30,000 on old bearing. New races, bearings and axel. Had HD set end play.
When i torque castle nut to 60 lbs. the castle nut goes beyond the cotter pin whole. Can i add a washer to bring cstle nut out with out changing end play? Also i do not rember the castle nut going that far on before the new bearings.
Thanks for any help EZD
Old Jul 28, 2008 | 10:21 AM
classof96's Avatar
classof96
Default RE: castle nut cotter pin rear wheel
The washer will not change end play. You should have had a washer there to begin with.
&nbsp\\;
Old Jul 28, 2008 | 10:31 AM
96 Wide Glide's Avatar
96 Wide Glide
I would want to know what changed to make your nut go farther into the axle than it used to.
Old Jul 28, 2008 | 10:41 AM
noreastermma
There is already a stock&nbsp\\;washer I will add another one. I can not figure out what changed to make castle nut thread on further than cotter pin whole. It seems as if i lost a spacer but everything is there?
Old Jul 28, 2008 | 11:08 AM
96 Wide Glide
The bearings are properly packed right?
Old Jul 28, 2008 | 06:40 PM
miacycles's Avatar
miacycles
Torque the nut to the lower torque number, that way if you have to tighten it more you will be OK.
Old Jul 28, 2008 | 09:01 PM
noreastermma
I added a washer exact same as stock. I torqued to 60 lbs and turned the castle nut a very little to line up the whole. It rolled fine on the stand in neutral and i rode it only 3 miles but it seems fine. Any other concerns i shhould have? Thanks EZD
Old Jul 29, 2008 | 01:12 AM
johntheone's Avatar
johntheone
Somethings not right, the width of the wheel spigot doesn't seem right. If you add a washer to bolster the width you need to ensure that the wheel alignment (offset) is not changed.&nbsp\\;
Old Jul 29, 2008 | 06:51 AM
noreastermma
Wheel spigot? I did check wheel alignment and its dead on with in a 32". I agree somthing does not seem right? There is no sign of any problem except the above mentioned castle nut. any other suggestions would be apreciated. Has anyone ever had this happen or heard of this happening? Thanks EZD
Old Jul 29, 2008 | 08:31 AM
miacycles's Avatar
miacycles
No problem, as you torque and re-torque it will change a little. Add new bearings andwhat happened is normal.
