1992 softail fat boy popping
Old Aug 7, 2008 | 12:31 PM
jackavelli's Avatar
jackavelli
Default 1992 softail fat boy popping
bike runs fine checked plugs they did not look bad but somewhat on the lean side bike does not pop but like every 15 to 20 minutes on highway and around town other than that bike is perfect gonna change plugs back to champion but what else could be my problem? any help would be greatly appreciated
Old Aug 7, 2008 | 12:33 PM
jackavelli's Avatar
jackavelli
some one please help
Old Aug 7, 2008 | 06:34 PM
t150vej's Avatar
t150vej
possible causes -
slight intake leak
tiny pinhole in carb diaphram
idle mixture screw missing the o-ring
FUEL CAP NOT VENTING
(remember) they HAVE to vent into the atmosphere as well as allow air inside the tank
Old Aug 14, 2008 | 11:11 AM
jackavelli's Avatar
jackavelli
anyone else got any ideas
Old Aug 16, 2008 | 08:36 AM
flashprez's Avatar
flashprez
Sounds like your timing is off just a little,or it could also be an intake manifold leak. Crank bike, spray a little wd-40 where manifold goes in to cylinders(both sides). If the motor revs up you need to replace o-rings there.
Old Aug 16, 2008 | 10:26 AM
92Fatty's Avatar
92Fatty
What carb you running? Popping out the exhaust would mean it is sucking air in somewhere. Fire it up cold and give the intake and carb area a shot with wd40 and see if idle changes. If it does means a leak. Any how it is sucking air in somewhere. Kent
Old Aug 18, 2008 | 10:16 PM
bucker18's Avatar
bucker18
i have a 92 heritage i had the same prob got to lookin around .. it was the manifold gasket with a hole in it .. take some carb cleaner spray around the manifold with the bike running if it shuts off thats your problem
MGDavis
EVO
58
Mar 15, 2018 11:36 PM
daddyskitchen@gmail.com
Jul 27, 2016 09:35 PM
lhgdale
May 25, 2016 01:14 PM
xrayted2
General Topics/Tech Tips
Jun 23, 2011 11:30 PM
edman6625
Exhaust System Topics
Jun 12, 2008 09:44 PM
