Cam Bearing-95 FXLR
Old Aug 29, 2008 | 04:06 PM
mp's Avatar
mp
Actually, I have found different info on the web. I found one place that says pn 9058B is the Torrington B138 bearing. There is also a pn9057 that is listed as a needle bearing, but I can't find anyplace that says specifically that this is the pn for the INA caged bearing. So the 9058 might very well be the right number. Wish you could trust the factory to use the good part. Call your dealer, maybe their part book has the specifics.
Edit: I just found another NOS parts list (nosparts.com) that specifically states that both 9058 and 9058B are Torrington bearings. It lists pn9057 as just "needle bearing, cam gearshaft". So I would say you're good on the 9058 bearing.
Old Aug 29, 2008 | 11:10 PM
Lakerat's Avatar
Lakerat
INA makes a full compliment needle bearing that is identical to the Torrington B-138
Old Sep 5, 2008 | 12:04 PM
Terp84Alum's Avatar
Terp84Alum
Just to follow up. I went to HD and had them pull the bearing for the bike-PN 9058. It's an INA piece of crap bearing. That should end any argument about what they are using.
Old Sep 5, 2008 | 10:59 PM
mp's Avatar
mp
Why would any dealer stock the INA bearing? Unbelievable.
Old Sep 18, 2008 | 02:31 AM
FLGEEZ's Avatar
FLGEEZ
Mine came apart evidently. Got a bit to replace with new. Cylinders,etc, cam and bearing and bushing, I was told the heads seem fine. Crank and flywheel may be fine. They have to split the case to clean all out. I didn't get a list of the total parts yet. First Flush is $3000.00. I am having all stock 80", stock cam, but Torrington bearing installed.
RE: the REMAN. I have heard from a builder and my local that there have been oil consumption problems. Victim/s have been told a Quart per 1000 is normal consumption on the reman. Not going there.
The pieces of the bearing sounded like a quarter in a dryer.. Not a good sound. Lasted for 57K.
Old Sep 18, 2008 | 05:32 PM
mp's Avatar
mp
Don't get a stock cam. An EV13 will do everything the stocker does, only better, and it doesn't hurt the fuel economy. Unless you like the new power so much you're constantly twisting the throttle.
Biker Boy 53
Aug 27, 2015 08:48 PM
Strahley
Engine Mechanical Topics
May 21, 2014 06:00 PM
sheem2153
EVO
15
Jun 9, 2010 07:17 PM
fj4069
Exhaust System Topics
Feb 12, 2008 09:36 PM
edsaws
Feb 6, 2006 08:37 PM
