Cam Bearing failure signs?
Old May 30, 2010 | 03:44 PM
sheem2153's Avatar
sheem2153
Default Cam Bearing failure signs?
Ive just started reading all of the different posts and of course the one thing that stands out is the Cam Bearing Failure. I have a '95 Fatboy that is approaching 32k miles. Are there any visible signs that will signify that the cam bearing is beginning to disintegrate? The reason I ask is just recently I pulled my air cleaner off to adjust my idle mixture screw. Well the 2 rubber connectors that feed the crankcase vents into the cleaner appeared to have some very fine metal particles inside.
So I figure if I see these particles on both sides the most likely place that would connect the two would be from the cam area. I cleaned them both out really well and will check again in a day or so to see if any more show up.
Could this be the cam bearing beginning to fail or could there be something else?
My lifter oil screen appeared clean but the particles I saw on the breather tubes were really fine so i may not have seen them when covered in oil?
Old May 30, 2010 | 05:45 PM
miacycles's Avatar
miacycles
Drag a magnet through them, that will tell you if they are steel or aluminum. Then you will have a better idea where to look.
Old May 30, 2010 | 05:51 PM
lionsm13's Avatar
lionsm13
Look at this way.. It would be a great time to put a new cam in er'..
Along with a new cam bearing ofcourse..
Old May 30, 2010 | 06:34 PM
sheem2153's Avatar
sheem2153
Yes , it would be a great time to do cam gear, cam bearing, lifters, adjustable rods as well but, I dont want to buy all of those parts only to find out that something else is going out that I wont be able to afford after purchasing everything else
I guess the best would be to just open it up to replace the cam bearing since I highly doubt that it is a torrington and see what I find in the process.
So aluminum flakes would suggest the INA cam bearing? and steel would suggest cam gear?
Old May 30, 2010 | 08:05 PM
miacycles's Avatar
miacycles
No steel would suggest something in the valve train, cam, gear, bearing, lifter, or other ferrous items.
Aluminum would suggest problems elsewhere vale spring/retainer hitting rocker box, worn rocker pivots, etc. Unfortunately steel is the most common as there are more pieces prone to wear that are steel.
Old May 30, 2010 | 10:21 PM
sheem2153's Avatar
sheem2153
ahhhh thank you miacycles!! Good info. Hopefully during my upcoming 3 day weekend I will be able to tear into it and see whats going on.
Old Jun 1, 2010 | 08:57 PM
tenn.vol.'s Avatar
tenn.vol.
Let me say, it will be ALOT cheaper before than after..
I went proactive on my 93 (it was good) new cam and bearing.
When I picked up my 97 RK, (which was bought new by a
mech. at Bay Side HD) I determined that he had purchsed a
new bearing at his place of employement. So I put two and two
togeether and HOPED he had replaced it.....WRONG!!!(32k miles)
And as we speak I am having the oil pump replaced now...
Money and piece of mind, just shotgun it with a new cam and
bearing.........Tenn.Vol.
Old Jun 3, 2010 | 10:08 PM
Jim Kraft's Avatar
Jim Kraft
My 99 has 24,000 miles on it, and am thinking about replacing the cam bearing only, along with adjustable push rods. Mine runs like a striped ape with what I think is the stock cam. Are the original stock cams OK to run in a new Torrington brg.? So far no valve train noise. Probably wait till next winter to do it, cause I will only have around 30 to 35,000 on it by then. In the mean time, I will continue to change oil every 2,000, and check for metal in the oil.
Old Jun 4, 2010 | 10:46 AM
96roadking's Avatar
96roadking
Yes, the dimensions of the bearings are the same, the Torrington has more rollers and less cage material than the INA. If it's a Stock cam it may have a single letter stamped on it, mine was an "N".
Old Jun 7, 2010 | 08:18 PM
hdkid's Avatar
hdkid
Stage II
If the cam bearing starts to get real bad the bike will start to idle like it has a high lift cam in it, also it will start to whine, kinda sounds like a hot rod runnin' gear to gear.
