fuel problem EFI EVO
Fuel filter... $60
3 dealers and so far they all state that it needs to be ordered.
one of them, this kid tried to tell me that my bike didn't have a filter.. keep in mind I have held it my hand and also seen it in the parts book. I had to finally tell the kid to quit arguing with me and open up the damn book... Sheeez
I also learned from this guy that just so happened to walk up to the parts counter that the Temp sensor will NOT always cause a egine code. He also had the same bike as I do. I learned more from him in 5 mins of talking to him about the fuel system than talking to 4 different harley shops. Why didn't Harley know that the temp sensor doesn't always show a fault code... give up ? because most of these guys couldn't fix anything that isn't in a service book.
Temp sensor.. $95 ( I bought one of those too)
This guy (old school biker) I spoke with even went so far as to tell me in two minutes the easiest, quickest way to change this sensor.
im, thanks for your input with this ordeal.
One thing that was posted is incorrect and that is... there is a sensor that does control the fuel/air mix at idle. It is located on the side of the throttle body on the right side.
The other thing is that the temp sensor will not always produce a engine code. I suspect this would be if the sensor is only malfuntioning and has not completely gone out.
I will address the temp sensor when I get home in a couple weeks, luckly HD in Rapid City had one in stock that I bought, but it looks like I'm gonna have to order that fuel filter though.
Good luck, hope your on to something.. Mine turned out to be the ignition pick-up wire..
I went on a nice ride with NO problems..
The bike even felt like it gained another 10-20 hp even. I say the filter was a major issue.
Maybe now I can get some riding in this week
The gas pictures was not from the gas tank but rather what dumped out from the fuel filter itself.
FYI....
I used your basic hose clamp to reconnect the filter but used the factory clamp for the cross over lines since it was in plain sight. Instead of buying HD tool to tighten/ crimp the factory clamp... I used a pair of tile nippers that is used to chip ceramic tile. I don't know what HD charges for their special crimpers, but the tile tool works the same way and I'm sure its a hell of a lot cheaper and does apply even pressure to both sides of the clamp (unlike wire cutters that apply pressure from back to front)
No need to remove the tank
CAREFULLY - Drain the gas out at the crossover hose at the front of the tank. ( you may need a second set of hands to hold the container you're draining into)
Remove the dashboard
open up the top panel to access the tank internals (about 16 screws)
You have to carefully release the fule pump bracket to release the fule pump. (This can be ornery - took me about 15 minutes to finally get it released)
Detach the check valve hose from the fuel pump
unscrew the check valve from the outside of the tank
install the new checkvalve with hose pre-attached.
Attach the hose to the fuel pump with supplied crimp clamps
Resecure the fuel pump
and button her back up......
I changed my fuel filter while I was at it, might want to do that while you're in there.
The MM system has a port on the bottom of the steel fuel tank connection line and can be measured with a pressure gauge, appreciate the indepth post from the member above but the MM system doesn't have the dreaded plastic hose failure as the Delphi system, it has internal steel lines joined by fuel grade rubber hoses and rule number one is don't always assume the problem is a computer controlled failure because it has on on it, even the seasoned techs still make this mistake.
Good to see the Evo members learning from each other and not afraid to be open minded and do what we do best "fix it ourselves"
