whirring sound
Old Sep 20, 2008 | 12:47 PM
rickincolorado's Avatar
rickincolorado
Stage II
Default whirring sound
I recently moved to Phoenix and the heat is taking it's toll on my 14 year old FatBoy (owned since new). After sitting out all day at work, and riding home over hot blacktop in 100+ degree heat, it develops a whirring sound that seems to be related to the actual speed of the bike (rather than the engine). I've replaced the front wheel bearing and lubed the speedo cable. Basically, when it's hot, if I pull in the clutch and let the engine go to idle, I hear this whirring as I coast - seemingly from the front half of the bike. It also is present when coasting with the clutch engaged and zero throttle. Interestingly, the sound disappears upon application of throttle.
Old Sep 20, 2008 | 01:52 PM
HGM's Avatar
HGM
I get that from my belt. Someone mentioned rubbing a little candle wax on the sides of the belt. I have yet to do it, but it sounds like a good idea.
Old Sep 20, 2008 | 07:17 PM
sqdealgeorge's Avatar
sqdealgeorge
HGM might have something here I always adjust my rear belt with 1 in play cold HD says different but 65,000 miles on the orig belt tells me I must be doing something right That is adjusted with a 10 # force
Old Sep 20, 2008 | 09:13 PM
oldroadie's Avatar
oldroadie
A little bar of soap gives a similar result...
Old Sep 21, 2008 | 07:47 AM
t150vej's Avatar
t150vej
Belt noise (and/or) vibration does change with temps and they get tighter with higher temps - just the opposite of what a chain does.
Takes some tinkering to find the right "cold adjusted" free play that works when up to temp.
Old Sep 21, 2008 | 02:52 PM
rickincolorado
Stage II
Is the belt noise explanation consistent with my experience of noise when coasting, no noise under load?
Old Sep 21, 2008 | 06:55 PM
HGM's Avatar
HGM
Thats when I notice mine..
e1976
May 5, 2015 03:45 PM
bayoubilly
Nov 24, 2009 02:28 PM
Calwoodbutcher
EVO
16
Dec 2, 2008 09:48 PM
marksfatboy
Jun 9, 2008 04:06 PM
bruski
Feb 5, 2008 02:38 PM
