oil pump bypass
Old Sep 24, 2008 | 06:37 PM
hotrod351's Avatar
hotrod351
Default oil pump bypass
i thought there was a screen of some type that you checked from time to time in the oil pump. i cant remember were it is. all i can find is where the oil pump bypass spring and valve is, is it under the valve.
Old Sep 24, 2008 | 07:58 PM
HGM's Avatar
HGM
Its not in the pump. While looking at the cam cover and pump(to the left of the cover). You'll see an acorn nut(plug) on top of the pump, then to the right, on the case, you'll see another acorn nut(again, plug). Remove that plug and you'll see the spring and screen inside. Its a little difficult to remove because of the contour of the case, but if you happened to read my post on lifter screen, they do make them aftermarket.
Old Sep 25, 2008 | 11:39 AM
hotrod351's Avatar
hotrod351
yeah i went back outside and found that out. thanks
Hairy Larry
Milwaukee Eight (M8)
35
Apr 5, 2019 09:42 PM
millosman
Shovelhead
11
Dec 16, 2017 11:10 AM
smnort
Shovelhead
Jul 5, 2013 10:01 PM
PANHEADMCC
Oil Archive (no new posts)
Jan 1, 2012 02:43 PM
rbabos
Exhaust System Topics
Aug 5, 2008 03:40 PM
