dampener for 91 softail
Old Oct 13, 2008 | 01:05 PM
stang9986's Avatar
stang9986
Default dampener for 91 softail
I just picked up a 91 softail custom with a 96" S&S in it. I was looking at installing a dampener to help cut down on the vibrations of the motor. I saw the a few companies make them and was wondering if anyone had any experience using them and if so what brand they recommended. If i get one to install it do i have to pull the inner primary or just the outer and the primary chain off.
Old Oct 13, 2008 | 01:52 PM
sqdealgeorge's Avatar
sqdealgeorge
I run Fisher front motor sprocket dampers on my 96S&S motors I does help They are on the expensive side My bikes have belt primarys For stock chain setups Jireh shows a 24T P/N 98-463 Never had much success with Balance Masters
Old Oct 14, 2008 | 08:06 AM
stang9986's Avatar
stang9986
thanks for the help how hard is the install do i have to pull the clutch out or just the front pulley
Old Oct 14, 2008 | 08:52 AM
sqdealgeorge
You do have to pull the clutch basket off also No big deal back off tension on the clutch rod remove clip pull out release plate you will see the nut behind it (left hand thread ) Pull off basket along with the front compensator (take bolt off chain tensioner) The whole unit front comp /prim chain/ clutch assembly will come off I use red locktite on both nuts I use an electric impact tool for this project If it was a belt drive primary all one has to do is install the fisher unit onto the engine shaft (goes inside the front belt pulley)
Stingray702
EVO
16
May 25, 2018 10:44 PM
waynemags
Custom Models
Jun 14, 2010 04:57 PM
PNHEAD
Panhead
Mar 31, 2007 09:43 PM
cjuroff
Nov 28, 2006 12:28 AM
