belt dressing?
Old Nov 7, 2008 | 02:04 AM
grbrown's Avatar
grbrown
Originally Posted by anubisss
One of the best things about a Harley is the lack of the need to lube and clean a chain...
Three cheers to that! A possibility is that your rear tyre may be touching the belt cover? I use Avon Venoms, which are a little wider than Dunlops, and when properly aligned the rear tyre just kisses the guard.
Both my old XB9R and current XB12R squeak when wheeling them around. A loud pipe is the best cure!
Old Nov 7, 2008 | 03:32 PM
t150vej's Avatar
t150vej
I have to adjust mine about 2" cold, then it's to specs when warm (usually 5 miles or less) A loose belt will squeak on softails - from experience. They will also squeak if they rub the pulley on the side.
They're made with Kevlar and nothing need be done but spray/wash when you clean the rear tire/wheel for piece of mind. And as mentioned before, they are tough.
mikeallenbrown
Aug 23, 2011 09:15 PM
Jpdyna
Nov 7, 2010 10:28 PM
AlCherry
Mar 14, 2009 07:34 AM
OKIEVO
Dec 21, 2007 12:10 PM
CorL
Jun 3, 2007 02:18 PM
