Upgrade Starter?
Old Feb 19, 2009 | 11:37 AM
MCSarge's Avatar
MCSarge
Default Upgrade Starter?
Hey guys been a while since I posted on the 87 Lowrider. I have the front torn down and the rear wheel and fender off. I have also stripped most of the wiring out. I am waiting until my extended tank and the 58mm front end get here before I pull the motor as I want to make sure I have enough clearance to avoid hitting the tank with the bars or it sitting to low on the frame.
Now my question is I want to upgrade the starter on this bike. It's a 1987 FXR Lowrider with the evo motor. can I put a late model starter on it and if so which one??
Thanks in advance for the help.
Old Feb 19, 2009 | 12:12 PM
grbrown's Avatar
grbrown
Hi Sarge,
Do you really need to fit a new starter? I have owned my 1990 bike from new, stroked it to 89" and fitted 10:1 pistons, then replaced it with an S&S 107" and still use the original starter! It works fine.
Old Feb 19, 2009 | 12:34 PM
sqdealgeorge's Avatar
sqdealgeorge
If you need a good aftermarket starter I run Spyke 1.4 KW starters on my early style starter set ups like yours The motors are 96 ci S&S
Old Feb 19, 2009 | 01:51 PM
t150vej's Avatar
t150vej
You can buy a stronger aftermarket starter motor, but you would have to change the inner and outer primary housings to convert to a "later" model starter assembly ('90 or later)
And be careful with replacement motors - there were 2 different ones used. Prestolite on the Shovels and Early Evos. In 87 they went to Hitachi which is a slightly shorter housing.
Old Feb 20, 2009 | 05:30 PM
bagga's Avatar
bagga
if it ain't broke, don't fix it.
Old Feb 20, 2009 | 08:12 PM
MCSarge's Avatar
MCSarge
I'll clean mine up and reuse it. Thanks for the advice.
75hdxlh1000
Nov 16, 2017 12:16 PM
tonycap
EVO
Mar 3, 2013 01:40 PM
watindes
EVO
Jul 3, 2012 04:06 PM
BigD48
EVO
15
Oct 25, 2011 06:45 AM
juaniosa
EVO
14
Mar 15, 2008 02:02 AM
