oil fill mark
Old Mar 11, 2009 | 10:48 AM
Buddy7394's Avatar
Buddy7394
That must be new for 99 softail ?
Cause even my '94 manual states only one line. The 'Add' line.
And full is up to the rubber on the dip stick.
Old Mar 11, 2009 | 11:06 AM
lionsm13's Avatar
lionsm13
Ya know what I was only trying to help the guy out. WGAF? Really?
Fill the CS up until it's runnin' over..then you'll know it's full.
Dipsticks,, sheeeesh....
Old Mar 11, 2009 | 01:40 PM
Buddy7394's Avatar
Buddy7394
Well, correct info is important.. Perhaps you don't get that ??
Since I used to own a 90 softail, & now a 94 softail, and both only have oem sticks an only "add" line.
Then that would be correctly answering the original question.
Can't say for '99, but if so, just learned somethin new. And if you are listening, you just learned something new as well..
Also my 97 R King has an upper mark & a lower mark, on dipstick.
Old Mar 27, 2009 | 05:39 PM
CaptJIM's Avatar
CaptJIM
88 Softail Custom here, with OEM dipstick...it has an upper groove and a lower groove...keep it between the lines when level and you're good to go.
Old Mar 28, 2009 | 05:48 AM
HD7585's Avatar
HD7585
85 fxst here, only has one line on the stick
Old Apr 1, 2009 | 04:41 AM
btroy's Avatar
btroy
89 FXR has two lines, between the two and ride on.
Old Jun 28, 2009 | 05:09 PM
Smorphine's Avatar
Smorphine
Hate to kick a dying horse but please clarify for me the oil level check procedure for a 1998 Heritage Softail (EVO). To check the oil level, check it hot (after a good ride) and with the bike upright (riding position, off kickstand) - Correct? My dipstick has two markers (lower and upper). Oil to be in that range. Is it best to have it in between the markers on an older EVO motor? Lowering the oil pressure?
Thx
Old Jun 28, 2009 | 05:56 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I`ve been riding a Softail for 21 years, and I couldn`t tell you if there is one line or 200 lines on the dipstick, I never look at it. I just eyeball the level, about 1/2 inch below the filler neck with bike level...
Old Jun 28, 2009 | 06:03 PM
Smorphine's Avatar
Smorphine
Hot or cold?
Thanks Dan.
Old Jun 28, 2009 | 06:41 PM
Dr.Hess's Avatar
Dr.Hess
Originally Posted by Smorphine
Hot or cold?
Yes....
