Cam Bushing question
Old Apr 14, 2009 | 10:19 PM
Rocketman69's Avatar
Rocketman69
Default Cam Bushing question
Ok....need some quick help.
I bought a replacement cam cover for my '97 Road King that has been powder coated wrinkle black. The new cover didn't come with the cam bushing, so I went to the only local indie shop that had one in stock which was a Jim's brand. Bring the bushing home, and it won't even fit over the end of the camshaft. Take it back and try the other one they have in stock...same issue.
So I order one from the dealer last week and picked it up today. It does fit over the end of the camshaft, but not very easily. It almost has to be forced on, but once on, it will spin. Very close tolerance.
So I need to know two things...(1) Are these bushings supposed to be clearanced to fit the cam, or is that normal to fit so tightly? and (2) The original bushing has what looks to be an oil passage drilled through it. Do I need to drill a hole in the new one?
Any help from those with experience is appreciated. Thanks in advance.
Old Apr 14, 2009 | 11:23 PM
mtnlvr's Avatar
mtnlvr
I believe the bushing is to be honed once it's pressed into the cover. Don't quote me on that though. Call your service dude or indy and ask him.
Old Apr 15, 2009 | 07:09 AM
bigtone's Avatar
bigtone
A new bushing needs to be reamed. The most correct way of doing that is line reaming through the cam bearing, with the case half removed. But if the engine is not disassembled, just find someone you can trust to ream it to fit the cam.
Old Apr 15, 2009 | 11:17 AM
t150vej's Avatar
t150vej
Precisely as stated above.
Many aftermarket nose cones come with bushings, some have to be reamed, some are pre-finished.
Problem nowdays, very few people have that ream and few HD shops even do any work like that anymore. And, the price of the tool and bushings (if you do the cam and pinion) are the same as the cost of the bushings and labor by an HD shop. You can buy a new OEM nose cone from HD (pre-fitted) for about that same price.
Been there - done that!
Maybe you'll get lucky and have an old Shovelhead wrench living nearby who has the tools and is in a generous mood....
P.S. Yes, you have to drill the oil hole AFTER installation and before reaming. Also, you have to drill for a dowel pin to prevent it from turning in the nose cone.
cowboy 51
EVO
18
Nov 27, 2014 02:58 PM
RidemyEVO
EVO
Feb 8, 2012 09:39 PM
WP50
EVO
Sep 11, 2011 06:13 AM
vicmaynard
EVO
Apr 23, 2010 05:57 AM
riden2low
EVO
Mar 6, 2007 08:20 PM
