Starter clutch replacement
Old Jun 20, 2009 | 06:40 AM
mulch63's Avatar
mulch63
Default Starter clutch replacement
Wifey's 98 Heritage starter finally gave out last night. Lately I notice a premature disengagement of the bendix/clutch. It now spins free when you hit the ignition. I have manual and determined I'll need the clutch ***'y but is there ANY other parts recommended to change ? I see the shaft spring and an O-ring in there as well?
jim
Old Jun 20, 2009 | 06:33 PM
sqdealgeorge's Avatar
sqdealgeorge
Probably the starter clutch inside the starter When you hit the starter is there a whizzing sound ?
Old Jun 20, 2009 | 08:53 PM
mulch63's Avatar
mulch63
Well called around and only one indy had a drive. I tore into the job and had the starter out about 2 hours. My biggest issue was the floor board to get at a primary cover screw and also the nuts for the oil tank. Need to have flexibility of tank to pull out starter.
Finished the job with cleanup in about 5 hrs. Longer then I wanted but HEY first time. Starts like a champ. HMMM only thing is I don't remember seeing the little ball between the solenoid spring and the shaft.
Well it must have stayed up in the end of shaft with grease. I hope....well too late now.
jim
FLHXRIDER88
Sep 23, 2015 09:02 PM
springer 03
Jul 18, 2013 07:57 PM
95 Ultra
EVO
Dec 16, 2012 08:03 PM
02glide
Nov 21, 2006 05:15 PM
DGlide04
Exhaust System Topics
Aug 27, 2006 10:32 PM
