Noise gone
Old Jun 22, 2009 | 08:46 AM
Red98RoadKing's Avatar
Red98RoadKing
Cool Noise gone
Yesterday I took a Fathers day road trip with my son in law and his dad thru northern Missouri (found a freakin cool road). I changed oil night before with 60 weight, thats the only thing I did. Now some of you know I've had a top end noise around the exhaust rocker for some time (change oil about 4 times since noise started, valve train parts at least one time) and I figured I'd give it one last hard run before I replaced the heads (best idea I had suggested to me) and if it lunched big deal. We ran hard with temps in the 90's and humid as hell.
After 130 miles running 70 - 90 mph the noise cured it self..... Why? Dunno. Runs great but it never ran bad. Hell I dunno what the cause was, kinda bugs me but what the heck turned out to be a great fathers day!!!
Old Jun 22, 2009 | 10:17 AM
mjunk1's Avatar
mjunk1
Occassionally in life you just have to take the gift, say thank you, and not look back. It is really nice when something fixes itself. Wish my wife would do that!
Old Jun 22, 2009 | 10:40 AM
Red98RoadKing
Ya we put about 260 miles on it and it never came back but like ya said take a gimme everytime.
Old Jun 22, 2009 | 12:59 PM
HGM's Avatar
HGM
OK, had you been running 60w all along or was this a new idea?
I'm willing to give it a try myself if it may fix it. I've done about everything, including headwork, to mine and havent fixed it yet. Couple of times, I thought it was better, but it's still not right...
Old Jun 22, 2009 | 11:05 PM
t150vej's Avatar
t150vej
It just dawned on me, woke me up in fact...
Remembering your having said it only rattled when it was warmed up and it had about 40,000 on the heads - what you may have had was a hot-spot in the combustion chamber or on the piston. Basically a small spot of carbon build up that was getting hot and acting like a glow plug causing some of the fuel to ignite before the plug lit the rest. That starts to add to the compression pressure before the piston reaches the firing point and causes a type of knock.
With this in mind, you may very well have "fixed" it with that good ride. If it starts doing it again, get it up to temp and pull the air cleaner, run it up to mid-range and with a hand spray bottle, spray water into the carb - that'll blast it out. Used to do that before every oil change, but when they quit making leaded fuel, I quit doing it.
Old Jun 23, 2009 | 04:48 AM
HGM's Avatar
HGM
Very good point, when I had my heads off a couple of months ago, the pictons were heavily carboned(30Kmi on the pistons).. The water will work wonders.
Old Jun 23, 2009 | 11:18 AM
Red98RoadKing
Thats the kicker I've had every weight oil from 10w40 upto 70 wt and had been running 70wt but I wanted fresh oil before heading out on a hot ride so I put 60 wt in it, they were out of 70wt. I don't think that had anything to do with it but what the heck do I know. I've been a wrench in a past life and this an't my first rodeo but it was pi**ing me off to no end trying to figre out the problem. I think the Hot spot diag. is got to be the right answer and if it happens again that wll be the first thing I try.
Old Jun 23, 2009 | 11:20 AM
Red98RoadKing
I will be doing exactally that if it happens again. BTW why didn't you say s before? LOL
Old Jun 23, 2009 | 12:28 PM
t150vej's Avatar
t150vej
Uh, well... all I can say is - it's just like everybody who's ever had a ghost while wrenching, it's the most insignificant, simple things that will slip your mind, get overlooked, forgotten and give you the most grief. Glad you didn't pull the heads straight away on my ramblings or suggestions, but then if you did and cleaned them, may have worked out just the same, but a lot of time and gaskets, maybe rings wasted.
And if it's any consulation, I split my cases last year for a deep knock - found nothing out of specs. Freshened it up and two weeks later it was knocking worse. I had re-used plugs that had 10,000 on them, put in a new pair, knock gone ... DUH! They were glowing and doing the pre-ignition thang I reckon.
Ride safe Bro.....
YUKON DAVE
Sep 5, 2018 06:25 AM
mang0
Sep 11, 2012 09:19 PM
TedMan
Exhaust System Topics
40
Apr 16, 2010 01:12 PM
Ben A
Screamin Eagle CVO Models
Jan 3, 2009 09:38 PM
ekcivic1
Nov 11, 2008 08:48 PM
