Motor mounts!?!?
Old Jul 16, 2009 | 11:19 PM
Brettfullthrottle's Avatar
Brettfullthrottle
Thumbs up
Originally Posted by miacycles
A large bar(padded so it won't scratch anything) that will fit in there and try to move it up and down, left and right. If it moves a lot , you have a bad motor mount!!!
Thanks a million! I was hoping you would jump in and you did! All you guys have given me VALUABLE information! Tommorow I think I will get out to the garage and try to move the motor! I am pretty sure a motor mount is bad! Question is,which one? Once I move the motor I should know. Oldroadie,thanks for taking the time to take the pics and explain step by step what should be done!
Old Jul 17, 2009 | 05:43 AM
oldroadie's Avatar
oldroadie
Our bikes use the same factory service manual so they're really similar. Just support the front of the motor with whatever's handy and loosen the two allen bolts holding the mount to the frame. If it moves back and leaves a large gap you'll know it's the rear mount; at least that's what I found on my '95. Seriously, though, the rubber is 13~14 years old and it's likely going south anyway so why not get ahead of the maintenance curve?
Old Jul 17, 2009 | 11:18 AM
Brettfullthrottle
Thats a good point...I really need to take care of this ASAP!
Old Jul 17, 2009 | 05:11 PM
mp's Avatar
mp
Originally Posted by Dr.Hess
What signs/symptoms are there when that thing is bad? I have this clunk when I go over a big bump that I've been trying to track down for the last few years. I think it's stuff in my saddle bags at this point, but I'm still not sure.
I get kind of a bottoming-out feeling thump when I hit big bumps, too ('92 FXRS), but no vibration or wallowing. I still assume it's a rubber mount going soft. Just started last year. Bike has over 140K on original mounts.
By the way does anyone else appreciate the fact that Doc Hess, who has helped numerous members with Evo problems and questions, isn't too proud to ask a question himself? This forum is one of the best resources for Evo owners on the web and it's because of guys like Doc, John, T150, Buddy and others who really go out of their way to share their knowledge. And now it looks like we have another in oldroadie. The Evo subforum is puny compared to others (even Off Topic for god's sake), but it's the best of hdforums without a doubt.
Old Jul 17, 2009 | 06:13 PM
tc's Avatar
tc
What's a rubber mount?
(Softail rider)
Old Jul 17, 2009 | 07:49 PM
miacycles's Avatar
miacycles
I think it's when you use a condom "rubber mount".
Old Jul 17, 2009 | 09:37 PM
Dr.Hess's Avatar
Dr.Hess
Yeah, John, that'd be a "Rubber Mount," versus "Bare Back." And the last study I saw (I don't actively look for them) said that "rubber mounts" had a failure rate of something like 30% or more in preventing HIV transmission.
mp,
I just try to help out. I don't know everything, but I do know quite a lot about quite a lot of different things, way beyond the Evo or even (shudder) Shovelheads. I've been riding HD's since 1979 and I bought my FLHT new 23 years ago next month. If I can share some of that knowledge and help someone out, that's what it's all about. I ain't too proud to ask for help either. And, BTW, I don't pass on "net wisdom" (stuff someone read somewhere on the net and passes on to everyone else like they are an expert on it.) If it is "net wisdom," and I think it may be accurate, I give a disclaimer of something like "I read on the net, take it for what it's worth."
Anyway, I don't have excess vibration, no sloppy feeling, everything feels right, I just get a klunk occasionally when I go over a big bump/hole. Fully loaded, I know I bottom out, but this year I built a trailer to take the weight off.
Old Jul 18, 2009 | 01:52 AM
Brettfullthrottle
Thumbs up
AMEN to that! You guys are great! I have learned alot about EVOS here,and although I don't post alot, I read from this forum quite often! So once again,I wan't to say THANKS to all you guys,your AWSOME!!
Old Jul 18, 2009 | 06:10 AM
oldroadie's Avatar
oldroadie
Nice mix of the old and the new here. While I've been riding and wrenching my own rides since 1972 I've only had my HD one year. I maintain a personal standard that keeps me from posting on any subject that I don't have direct experience with; this past year I've been well schooled by my Dyna: replacing the disc brake pads, flushing the brake system, replacing the transmission output seals and the primary gaskets, installing new tires, installing new motor mounts, aligning the motor and frame and the usual carb tweaking, timing adjustments and fluid replacements. Beyond that I wouldn't be comfortable offering any advice.
Old Jul 18, 2009 | 08:22 AM
dog155's Avatar
dog155
The FLH/FLT models have different motor mounts,with stabilizer bars to adjust alignment.
