Motor mounts!?!?
Old Jul 18, 2009 | 08:21 PM
MJ's Avatar
MJ
Hey Brett,
Don't think you would mind if I jump into your thread here because of me talking about the isolators. I read in the evo section every day, but very seldom post and now twice in one day, because I just started another thread here.
About 6000 miles ago on my 1998 FXDWG with 45,000 miles on it, I started noticing more vibration at idle. I read many of the other threads about the isolators and have been suspecting they are going bad. Well a few months ago, I bought an angle finder and checked the front wheel rotor compared to the rear rotor to make sure they were even and perpendicular to the bottom of the frame. Well I found that the rear was off by almost 3 degrees. I first loosened the mounts and following the directions in the service manual, I idled the engine for a few seconds to "set" the engine into the frame. I checked the shocks and horizontal alignment in relation to the front wheel. Horizontal alignment was fine, but the vertical was still off by 3 degrees. I was thinking then "How could the vertical alignment suddenly be off that much when the bike has not been in an accident". I removed the gas tank, loosened the front and rear isolator and adjusted the top stabilizer link until the rear wheel was perfectly at 90 degrees just like the front wheel. Well it did help a little on the vibration for a while, but now it is back along with another problem. The bike when the saddle bags are on and loaded with more weight wants to "wobble" in the rear at speeds over 70 when I am around truck traffic or on windy days. It does not do this all the time, just occasionally, but sure causes a butt pucker when it happens. The more I read about the isolators, the more I think they have deteriorated to the point that they have lost some of their rigidity.
Comments and suggestions are welcomed.
Old Jul 19, 2009 | 12:21 AM
Brettfullthrottle's Avatar
Brettfullthrottle
Originally Posted by wideglide95th
Hey Brett,
The only time I experienced what your describing is when my rear tire was put on and the tech(I work with him) didn't allign the rear wheel properly. between 70-80 the bike developed a very nerve-racking wobble. Didn't like that at all! alligned the rear with a friend and now its fine! The only time it develops now is in a left sweeper and that seems to be caused by a bad motor mount. I lifted the motor on one side with a long bar this morning-sure enough,she seemed to lift a little more than she should.
I'm fine with you jumping in-the more the better as far as I am concerned. I might just learn more about my bike....I can never learn too much!
Old Jul 19, 2009 | 08:12 AM
Buddy WMC's Avatar
Buddy WMC
I'm not a Dyna guy, but a rubber mount is a rubber mount. My real 93 FXR is a bit different in the way the front mount is designed. Our EVO'S are older bikes and the rubber does not last forever. During my rebuild, I replaced the rear swingarm Cleveblock system with the CCE Spherical Bearing kit, installed a new HD front mount, V-Thunder stabilizers and replaced all of the rubber parts on the bike.
Let's be realistic these parts were over 15 years old. I also discovered that the previous owner had the drive belt replaced by an Indy. The guy cheated by removing just enough of the left side of the swingarm to slide the new belt into place. Upon reassembly, the inner nylon washer was not aligned properly and was chewed up. The pulley spacer was corroded and never replaced causing a transmission leak shortly afterwards.
The CCE rear swingarm kit took all of the sway out of the rear end and the bike tracks like it's on rails. This kit still utilizes the outside rubbers, so there is still rubber mounted dampening to a certain extent. Not saying that you need to go there, but something worth thinking about. I'd sure think about replacing those other mounts and rubber parts though. Not a fun job, but nice to know that the parts are new and will last for awhile.
Old Jul 19, 2009 | 07:33 PM
miacycles's Avatar
miacycles
Hey Brett you might want to get in touch with one of the moderators, your last 4 posts are all numbered #83. You will never get to Road Captain that way!!!
bringtheruckus
Aug 30, 2016 09:49 AM
dynawg1
Apr 1, 2015 08:37 AM
Son of PMS
EVO
18
Jul 22, 2014 08:39 PM
stng_96
Sep 2, 2008 12:22 PM
SLICK SALZ
Apr 30, 2008 11:30 AM
