View Poll Results: Does a single fire ignition on an EVO worth the money?
Yes
29.17%
No
16.67%
Not sure
25.00%
If it ain't broke don't fix it, keep it stock.
29.17%
Voters: 24. You may not vote on this poll
Single Fire Ignition
Old Jul 13, 2010 | 03:59 AM
96roadking's Avatar
96roadking
Originally Posted by 1997bagger
97-98 MM EFI does have single fire.
my 96 also is MM EFI and single fire.
Old Jul 13, 2010 | 07:50 AM
MDodson's Avatar
MDodson
All the ones who went to single fire. Do you still have and want to sell your dual fire parts? If so pm what you have if it will fit a 91 UltraClassic.
Old Jul 13, 2010 | 08:39 PM
JohnG3's Avatar
JohnG3
Any recommendations on the single fire coil? My 96 FLSTC already has the Dyna 2000 ignition module set for dual fire. My understanding is I just need the single fire coil?
Old Jul 13, 2010 | 08:46 PM
NorthGeorgiaHawg's Avatar
NorthGeorgiaHawg
You will also need to run another wire from the Dyna ignition module to the single-fire coil to run the second cylinder with. Single fire requires one wire for each cylinder coil. The single fire coil will have three connections on it - in contrast to the dual fire coil, which has only two connections.
The Dyna instructions should tell you how to wire for single fire.
98hotrodfatboy
EVO
35
Mar 29, 2016 07:25 PM
98Evolish
Aug 28, 2012 06:44 AM
JohnnyC
EVO
Nov 10, 2010 04:04 PM
rivercityslim
EVO
14
Aug 12, 2007 03:20 PM
84sugar
Sep 22, 2006 03:16 AM
