Ticking EVO
Old Aug 25, 2009 | 05:23 AM
btroy's Avatar
btroy
Originally Posted by lionsm13
I also have a metalic sounding ringing sound though, that has not yet been determined....Replaced the cam bearing.
I have this sound when in first gear, after that it goes away, Or maybe its too loud to notice after that. Runs fine but I don't chase every sound I hear anymore.
Old Aug 26, 2009 | 07:24 AM
lionsm13's Avatar
lionsm13
Yeah, maybe I shouldn't either, but it's a new sound to me and I've had the bike 8 years now, and the sound appears to be there all the time. Sort of sounds like it's coming from the primary but the chain is tight. It has a M6 auto chain tensioner. It does it in idle and in gear both.
Old Aug 27, 2009 | 05:57 AM
2cyclejohn's Avatar
2cyclejohn
Guys, be dang sure to check that pinion gear, take it off, clean it and examine witha magnifiying glass. I had one bad tooth where it had worn thru the hardness. My tick was gone after 3 years of maddness and frustration.
John
Old Aug 27, 2009 | 08:18 AM
HGM's Avatar
HGM
John
OK, dumb question from a car guy... What are you calling the "pinion gear"?
Old Aug 28, 2009 | 05:33 AM
btroy's Avatar
btroy
+1? what is that
Old Aug 28, 2009 | 07:23 AM
t150vej's Avatar
t150vej
Originally Posted by btroy
+1? what is that
Right side flywheel shaft is the pinion shaft, sometimes called the gear shaft. There's a helical gear, that looks like a sleeve, which drives the oil pump gear shaft. The gear on the end of the pinion shaft drives the cam gear. Left (drive side) shaft on the flywheel is the sprocket shaft.
If the pinion gear is mismatched to the cam gear, they will either whine excessively (too tight) or click, if too loose. And of course a bad tooth on the gear will make noise and a cracked gear will cause a deep knock, though that's not a common failure.
Old Aug 28, 2009 | 08:32 AM
HGM's Avatar
HGM
Makes sense, thanks Rufus.
Old Jun 7, 2012 | 12:24 PM
deleontow's Avatar
deleontow
Seems I should have followed up on this post. Well the motor mount issue was someone tried to adjust the mount bracket, maybe to help with the high speed wobble that Touring bikes have, they put this too tight and it was causing exteme lateral pressure. Set up alignment on the motor to the factory spects and I have not broken another mount bolt. As for the ticking on mine it turned out to be the compensating sprocket. We replaced it with a new one and the noise is gone. The engine does have a slight tick still, but you can only hear it if you listen for it. I figured this is some what normal. Just a note, we ended up having to pull the crank out again, as the harley dealer did not have the correct alignment. It was causing the wrist pins to blow out. After 4 cylinders, I installed a different crank and that was over 40,000 miles with no more problems.
PGSD1
EVO
Jun 12, 2017 10:27 PM
jrscars
Nov 19, 2012 01:17 PM
lieutenant G
EVO
15
Dec 7, 2011 10:49 PM
Fatboy931
EVO
Mar 25, 2008 07:55 AM
Steve On 3
Exhaust System Topics
Jun 20, 2006 10:58 AM
