Need forks for 1984 FLTC
Old Aug 29, 2009 | 03:40 PM
sunup420's Avatar
sunup420
2nd Gear
Default Need forks for 1984 FLTC
Having trouble finding forks for this bike will buy any that fit.Thanks
Old Aug 29, 2009 | 06:22 PM
bigtone's Avatar
bigtone
Just what are you looking for, the entire front end, or tubes or what? Not many differences tru the years from 80 to mid 90's.
Old Aug 30, 2009 | 06:34 AM
sunup420's Avatar
sunup420
2nd Gear
Looking for the tubes dual disc and calipers.I have the triple tree nothing else
Old Aug 30, 2009 | 08:03 AM
FastHarley's Avatar
FastHarley
Former Sponsor
If you wish you can upgrade your bike with a 2000 & up set of forks (all you are looking for is the lowers). You can put a new axle and wheel and dump your Timpen tapered bearings in favor for a sealed double row ball bearing type.
You will need a late style set of (2.220" register hole) rotors to fit the new front wheel. Your choice of calipers/rotors are twin cam caliper/11.5" rotor or HD Brembo/300 mm rotors. I believe you have a 10" rotor(s) but I do not know for sure.
The brake upgrade is worth it alone as is the bearing upgrade. The difference between stopping distance decreases with each tier single piston you have ..to.. Twin Cam ..to..Brembo.
The 41 mm forks will fit right into your trees. Here is a conversion I did on a friends 1967 FL. We hated to do this but the choices of living & riding in Fort Lauderdale are:
a) Leave your drum brake front wheel equipped bike in the garage and look at it.
b) Risk a crash every time you leave the garage and know that it is a matter when and not if you are going to crash into some cage'r. The drivers here are unique to anywhere in the US. They suck, I mean really, really, really SUCK!
Old Aug 30, 2009 | 08:05 AM
t150vej's Avatar
t150vej
84 thru 99 should work since you're basically starting from scratch.
jthemouth
Aug 31, 2017 04:32 AM
nc883
Mar 14, 2012 10:00 AM
old glide
Oct 3, 2011 11:49 AM
CRF
Jul 17, 2010 07:14 PM
Frankensteineken
Oct 18, 2009 03:40 PM
