Intro and 60k Evo manintenance....
Rare problem on evos, but I had it
I bought my bike new. Opened the box myself. I have over 75K miles now, took it 2K miles to Sturgis and back this year pulling a trailer, passing many a twinky.
The guys here in the Evo section know lots about them and don't mind sharing that knowledge. This is where I heard there was a problem with that inner cam bearing, and that my bike was pre-problem.
The big difference between the Evo forum and the Touring forum:
On the Evo forum:
I just bought a Evo with 100K miles on it. My front wheel comes off the ground in 2nd gear when I nail it. My friend's does that in 3rd. Should I change the oil?
On the Touring board:
I just bought a 2010 Ultra Classic FLHTUCEIEIO. Is it normal to get a 2nd degree burn on your thighs from the engine heat? How can I mount my 500 watt base cannon and still have enough amps left over for my 1KW electric underwear? I only have 20 miles on it, but I want new mufflers that sound just right, ear splitting but not drowing out the stereo. Will the Kury's do that?
On the evo forum:
I just bought a evo with 100k miles on it. My front wheel comes off the ground in 2nd gear when i nail it. My friend's does that in 3rd. Should i change the oil?
On the touring board:
I just bought a 2010 ultra classic flhtuceieio. Is it normal to get a 2nd degree burn on your thighs from the engine heat? How can i mount my 500 watt base cannon and still have enough amps left over for my 1kw electric underwear? I only have 20 miles on it, but i want new mufflers that sound just right, ear splitting but not drowing out the stereo. Will the kury's do that?
Guess you already know to buy a shop and parts manuals. Well worth it.
60k on the clock, just getting warmed up (as long as it was taken care of).
Don't forget to go to "Show me your EVO" section for some pictures.
Dont mean to hijack, but after I saw this thread and the other links in it its got me scared **** as to what my bike has in it? Previous owner just said he upgraded the cams, didnt mention anything about the bearing.
jtmurph - I'm glad you asked that question, I was getting ready to ask the same thing. How do you tell btwn the INA and the Torrington? I'm heading to the stealership this morning to pick up a Torrington, it's only $8 bucks so if it just hangs out no big deal.
So here is my list so far:
DONE:
I Ordered a Memphis shades batwing with 7" windshield- $300
Picked up a Badlander seat for non-touring duties and days with no tour pack - $200
Complete fluid change - $40
THIS WKND:
B Lifters - $207
EV27 Cam - $135
Shim set - $24.99
Torrington Cam Bearing - $8
New Primary Gasket - $85
Adjustable Push Rods - $77
Valve Service - My time
Keep an eye on the Sprocket Shaft Seal
$1,077 total, with $500 being for aesthetic purposes. Not too bad if it pretty much makes the bike bulletproof again.
Buy quality push rods also. People have been disappointed with stuff off eBay when they bend or the nuts come loose. And make sure they are "Easy" install pushrods, because there are adjustable pushrods out there that you still have to pull the top of the motor off to put in, including those sold as "Screaming Eagle." Ask me how I know.
From the Touring board: I just got passed by this Evo that pulled the front wheel off when he hit 2nd. If I upgrade to a 103" high compression, flowed heads and big cams, will I be able to keep up?
