Can you over fill brake fluid?
Old Oct 25, 2009 | 02:18 PM
I8SMK4U's Avatar
I8SMK4U
Default Can you over fill brake fluid?
I just put a new brake line on. Its been working OK but getting harder. Now I can't pull the lever in. I know I filled the thing up. Can you put too much in?
Old Oct 25, 2009 | 02:29 PM
sqdealgeorge's Avatar
sqdealgeorge
Open the bleeder Pump all the fluid out Start again Dot 5 I hope Give it a shot !
Old Oct 25, 2009 | 09:31 PM
I8SMK4U's Avatar
I8SMK4U
Problem found, its in the lever. The piston is not comming out far enough and comming out of the little barrel thats in the lever. Looks like a rebuild for me.
Old Oct 26, 2009 | 05:19 AM
miacycles's Avatar
miacycles
Sounds like someone squeezed the lever when the line was off and the piston is stuck in.
Old Oct 26, 2009 | 10:45 PM
I8SMK4U's Avatar
I8SMK4U
I love and hate working on my own stuff. I think I got it. I lined it all back up (Cold, at night). It worked a little, then rode 1.5 hours to class (the next day). She sat in the sun all day (Warmed up), when I went to leave class I had a substantial amount more break control. I am going to judge = improper brake bleeding. I have to work at it more.
Old Oct 27, 2009 | 11:53 AM
miacycles's Avatar
miacycles
Get a replacement bleeder screw called Speed Bleeders. They work the nuts. Makes a professional brake bleeder out of almost anyone.
Old Oct 29, 2009 | 09:49 AM
guspup's Avatar
guspup
6th Gear
Yes you can over fill brake fluid? I know a guy who filled his master cylinder for his rear brake. (Located next the exhaust) before a road trip. About 40 miles into the ride, the heat caused the brake fluid to expand and his rear wheel to lock up on the freeway! He was very lucky he did not go down!!! Yes you can over fill brake fluid.
cencal
Jan 9, 2017 05:11 PM
TXagENGR
Mar 11, 2012 11:27 AM
AusMongrel
Oct 31, 2010 02:45 AM
MotorSgt
Mar 18, 2009 05:15 PM
NOLAMike
Jan 22, 2009 08:06 PM
