Single fire Ignition?
The power difference with this cam is great! (86 TQ to rear wheel!) with no other mods due to a desire for this motor to last and last! She runs like a swiss watch. My one complaint is gas mileage. She now only gets about 36 MPG and it has been on the dyno.
Local indy said I should install a single fire ignition. He stated more gas mileage as well as power! Any experience with an ignition and my set up?
I never had the modified 80" on the dyno so I can't say with certainty how much power it had. The best CV carb set up I had was put together by Wally Kerstetter in Sunbury Pa 17801. It only took a couple days and at that time was about $120. The fellow that recommended Wally said he got 42 mpg after Wally worked on his carb. http://www.harleydavcvcarbrebuild.com/
One thing about dyno tuning is that they can/will only tune for maximum performance. Most often that equates to lower economy. Sometimes you can give up a tiny bit of performance, often without any noticable lose of power, and gain a good bit of fuel mileage. Since you're tuned to the "max" performance-wise, you can de-tune slightly and help your mileage.
Fact is, as previously mentioned, there is no gain in power, torque, or mileage going from dual fire to single fire.
No documented evidence at all. Period.
And the thought that the engine runs smoother is questionable, as well....
Here's what Nightrider has to say about the topic:
http://www.nightrider.com/biketech/h...ionmodules.htm
http://www.nightrider.com/biketech/hdseignition.htm
Don't misunderstand, I'm not saying that single fire ignition isn't the way to go for you. Do as you see fit for your machine.
I know plenty of guys who run a single fire system with no trouble
All I'm saying is that if you expect a gain in power and mileage by switching out your ignition system to single fire, you'll probably be unhappy with the results, as many have been.
The dual fire Screamin' Eagle ignition system I run has performed flawlessly, easy install, (plug and play), and costs less.
As far as your mileage, it really depends on your style of riding, and the tune of your machine....
If it were me, I'd start there....
Your 38 mpg could be from a number of things. Running around the city or suburbia, gunning it from stoplight to stoplight. Sitting at idle and constantly 'blipping' the throttle. It doesn't take a lot to lose a couple mpg.
The CV carb got a really bad rap back then, mostly due to the EPA restrictions. The MoCo had the jetting set very lean, so the first thing everyone did was remove the plug and adjust the mixture screw.
Homework: Top off the tank, take the bike out on the interstate and run at a constant speed for 50-100 miles. Top off the tank, and do the math.
